MarineIguana Posted June 9, 2011 Author Share Posted June 9, 2011 That's on my list of things to do breathers are clear and the stem seals are new Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 9, 2011 Author Share Posted June 9, 2011 Head gasket failure causing oil between cylinders, So head will most likely be warped so it will be sent of to be skimmed Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 10, 2011 Author Share Posted June 10, 2011 Have a few photos first one is of valves you can see the oily two on the right And you can see where the oil got past the gasket in the other two pics Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 16, 2011 Author Share Posted June 16, 2011 And 0.006 taken off later we have this And the engine is naked Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted June 16, 2011 Share Posted June 16, 2011 turn the crank around so all the piston sit half way down, pour in some, petrol or oil and leave over night. check in the morning to see if fluid is still there, easy way to check rig seal Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 17, 2011 Author Share Posted June 17, 2011 Well the engine is out and piston 3 is looking a bit rough All other bores and pistons look like this And the clutch is well past it And I have found my engine number at last in the wrong place but its there Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted June 17, 2011 Share Posted June 17, 2011 is that scores in the bore on the left hand side, and chips , or is it water marks? the top of the piston, doesnt look that bad, just the valve recess you are seeing, along with some gasket residue you not rebuilding it, while its apart? Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 18, 2011 Share Posted June 18, 2011 that clutch looks a bit mullerd Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 18, 2011 Author Share Posted June 18, 2011 Been degreasing stuff today shame i forgot to get a before pic of the engine bay but it was thick black sludge But here it is ready to be prepped for spraying Gearbox housing erm a bit dirty i thinks Halfway done now Hope to have new engine in when i get hold of the geezer and have it on the road sooner than i thought Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 19, 2011 Author Share Posted June 19, 2011 I have the engine it has sat for a while but came out of a 40-50k mile C or D reg turbo that was a write off Its like new it is unreal so happy with it all for £100 he also might have a ECU and complete loom for it thrown in It will be painted white too and cleaned up to a decent standard the turbo is in better condition than mine and has the water cooling pipes which are hard to get cheap And the engine bay is getting done. Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 19, 2011 Share Posted June 19, 2011 that engine is a great buy at 100 quid! good to see you doing the engine bay mate, looks a little worse for wear, your not holding back on it, good man i shall be keeping an eye on what your doing with the engine bay, as there my next plans Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 19, 2011 Author Share Posted June 19, 2011 It's something I have wanted to do but just haven't got round to it so while its like it is I'll clean it up will make it a better looking car at the end of the day And I might fit my chrome turbo housing if I can sat on a shelf for far too long lol Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 20, 2011 Author Share Posted June 20, 2011 The new turbo with its shiny housing fitted Quote Link to comment Share on other sites More sharing options...
Guest cossiemark Posted June 20, 2011 Share Posted June 20, 2011 looking nice m8 Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 20, 2011 Author Share Posted June 20, 2011 While it rains I finished painting the engine mount Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted June 21, 2011 Share Posted June 21, 2011 Do as much as you can before you put engine in m8 it will look alot better.....you need Basilbear over there she loves cleaning Good luck with re-build Al hope it goes well Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 21, 2011 Author Share Posted June 21, 2011 One wing done check out my overspray And engine painted Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 23, 2011 Author Share Posted June 23, 2011 Few more bits done today, Got head back from shop and its a better head than the old one cleaner and tighter Gearbox is out and will be painted gloss black at the weekend And a genuine ford head gasket Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 24, 2011 Author Share Posted June 24, 2011 Bit more work done today got the help of my younger brother Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 24, 2011 Share Posted June 24, 2011 good to see safety 1st with the gooooogals!! mine will look like that soon! coming along smooth mate Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 24, 2011 Author Share Posted June 24, 2011 Those are the cool goggles tinted and awesome Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 26, 2011 Author Share Posted June 26, 2011 Engine & gearbox painted Quote Link to comment Share on other sites More sharing options...
Basilbear Posted June 26, 2011 Share Posted June 26, 2011 Thats looks brilliant Allen, love the black and white. Can't wait to see him at ford fair! Thanks Avril Quote Link to comment Share on other sites More sharing options...
badger Posted June 26, 2011 Share Posted June 26, 2011 looking really nice keep up the good work Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted July 1, 2011 Author Share Posted July 1, 2011 Well its in Quote Link to comment Share on other sites More sharing options...
