Guest gavintwopies Posted September 1, 2010 Share Posted September 1, 2010 Well i finally managed to squeeze in getting the duffer wing drilled off 2 days ago, but aint had time to get on the net to add the photo so here goes, i'm constantly supprised as to how solid this car actually is, looks pretty goodunder the wings. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted September 1, 2010 Share Posted September 1, 2010 mmmmmmmmmmmm pink cabbie colour dont look to bad as ginger said not many pink cabbie's out there... Sure your's will stand out tho by the way your wing's fallen off Looking good tho keep the pic's coming of how you getting on doing a good job fella Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted September 1, 2010 Share Posted September 1, 2010 keep up the good work mate Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 2, 2010 Share Posted September 2, 2010 Small update finally got another bonnet and faffed with it for 20mins to get it all squared up looks a lot straighter now, also new wing purchased and clipped in place too.ready to weld it on tommorrow. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 4, 2010 Share Posted September 4, 2010 (edited) Well i finally got round to swapping the mk3 heater box for the mk4 one... then after that i got cracking on the mk4 dash conversion with a bit of guidence off another website its a doddle. 1st on the agenda, get a bit excited with an angle grinder, after all the windscreen is knackerd so no need to worry about that !!!!! Edited September 4, 2010 by gavintwopies Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 4, 2010 Share Posted September 4, 2010 well after fitting most of the heater vents tubing and having to drill and tap 3 m6 holes across the top of the bulkhead to match the dash its almost looks factory fit. beauty of drilling and tapping the 3 holes is they actually work and tighten up as they should and look std too. Quote Link to comment Share on other sites More sharing options...
gingergman Posted September 4, 2010 Share Posted September 4, 2010 im liking the pic of the grinder action good work mate Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 4, 2010 Share Posted September 4, 2010 Not much is happening with the cabby at the minute as i'm also currently helping out with the building of a mk4 escort 5 door rwd conversion but it will get done soon . Once i get my welder trolley sorted out i'll have the new passenger side wing on and all daft spots solid again. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 5, 2010 Share Posted September 5, 2010 (edited) just been putting the finishing touches to the back of the mk4 dash as when fitting it to a mk3 there is no mounting points for the windscreen heater vents so they need screwing to the back of the dash and sealing up , I used sticka flex windscreen sealant & b&q self 12mm tappers for that better than std seal. at this point i have nothing left to do to the dash bar let the sealant go off and re-fit the dash. Edited September 5, 2010 by gavintwopies Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 9, 2010 Share Posted September 9, 2010 Well finally got a bit time to start putting the finished modified mk4 dash in and it fits like a glove just a few little niggly little bits i need to pick up now mk4 steering wheel, indicator screws etc,etc As you can see the normal routing of the mk3 loom is no good behind the mk4 dash so having the loom susspended on string off the hammerd flat metal tags does the trick. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 20, 2010 Share Posted September 20, 2010 Looks like the wait is ove,r just 7 days till the paint makes its way onto the motor. Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted September 20, 2010 Share Posted September 20, 2010 Getting there then I take it Quote Link to comment Share on other sites More sharing options...
gingergman Posted September 20, 2010 Share Posted September 20, 2010 it takes a real man to wear pink cant wait for the pics! Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 21, 2010 Share Posted September 21, 2010 Getting there then I take it Yeah jsut everything has been put on the back burner as i have desided to pass the buck to me m8 and give him a bit cash in hand for doing it, now he has his unit. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 21, 2010 Share Posted September 21, 2010 it takes a real man to wear pink cant wait for the pics! Its not going to be that camp you know its going to have a s1 kit fitted to it!!! just been looking into making myself some banned steels and going to try stretching some tyres too dont know how they will turn out but will deffo be with a look if there any good i might, thats a BIG might put some on the cabby. Quote Link to comment Share on other sites More sharing options...
gingergman Posted September 21, 2010 Share Posted September 21, 2010 stretched tyres on banded steels should stay on vdubs! Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted September 21, 2010 Share Posted September 21, 2010 stretched tyres on banded steels should stay on vdubs! Well when was the last time we seen an escort on them for comparison? i aint ever seen one so thought what the hell. Quote Link to comment Share on other sites More sharing options...
gingergman Posted October 3, 2010 Share Posted October 3, 2010 its gotta be pink by now??? Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted October 9, 2010 Share Posted October 9, 2010 (edited) Well a slight turn of events with the car turning pink, it all started when my missus stuck her daily driver megane td into some motorway slip road railings. then after the car was a total write off we had to go looking for an emergency replacment as she is a mobile carer for old people and the infirm. armed with just under £300 i had a challenge on, it had to have mot and some tax if any. and what do you know this reared its ugly face......... Edited October 9, 2010 by gavintwopies Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted October 9, 2010 Share Posted October 9, 2010 (edited) So it would appear that this mot'd and taxed version of the cabby is now going to be turned pink and that leaves me the other one wondering what i can do to it..... Edited October 9, 2010 by gavintwopies Quote Link to comment Share on other sites More sharing options...
gingergman Posted October 9, 2010 Share Posted October 9, 2010 cabby grave yard not bad for 300 notes! Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted October 10, 2010 Share Posted October 10, 2010 Can change your username to Gavintwopinks :D Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted October 12, 2010 Share Posted October 12, 2010 well finally "D" day has landed..... IT would appear the car should have some of the pink stuff on it about this weekend!!! photos of tonights strip down witha a few little bits of assistance from me. also note the body shop humour withthe home made windscreen decals. Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted October 13, 2010 Share Posted October 13, 2010 Lol at windscreen So not long till P day arrives Quote Link to comment Share on other sites More sharing options...
gingergman Posted October 13, 2010 Share Posted October 13, 2010 cant wait to see it pink mate, i hope its mega bright lol Quote Link to comment Share on other sites More sharing options...
