Getting Started
Guest El87cabi
Guest El87cabi
Added an old skool bit of badging :smile:
Went to a show :smile:
Added some more 'badging' :wink:
Went to another show
Really need some more centre caps
Meanwhile back at home.....
Parts are starting to arrive :biggrin:
  • Replies 127
  • Created
  • Last Reply
Top Posters In This Topic
Guest El87cabi
Just so everyone is aware, Stack gauges DO NOT FIT into aftermarket pods ffs :dry:
Anywhoo
Matt's been busy doing some stirling work on my spare head :biggrin:
And just some icing on the cake....
Anyone know what's different about this throttle body?
Guest El87cabi
While Matt was busy preparing the head, i was up to my old tricks
I'd sprung a leak - an oil leak - from a cracked sump :sad:
This is sump no.1 before fitting by me
I knew from the off something wasn't right about this but as Ford Fair was a stones throw away i had few options
Few random under car shots :smile:
Guest El87cabi
Ooo lookie, clean enough to still see the rebuild date on my turbo 'box :smile:
Kinda run outa light :sad:
Sump on :cool:
Off to Ford Fair :biggrin:
Car outside my Mechanic's ready for sump no2 lol
My idea of a 'fitted' oil pressure gauge lol
End of year roof down shots, the stage 2 head is now on and working well. It also now runs on a Newman Cam and solid tappets :biggrin:
Unfortunately now all the leaks on the top end have been plugged Matt has told me the old girl won't pass another mot as A. my cylinder pressure is appx 50psi per pot :blink: and B. my emissions are well out :unsure: All i'm gonna say is if your behind me roll up the windows lmao.
Time for a bottom end rebuild :sleep:
Edited by El87cabi
  • 5 months later...
Guest El87cabi
Hey all, been i while since i did an update on the old girls progress, I'll start with head swap over photos and go from there :smile:
Off with the old
Then on with the new :laugh:
Nicely smoothed Throttle body :biggrin:
Airbox out.....
Pipercross in :cool:
Guest El87cabi
That was works carried out last year, after a fair amount of driving and showing the Cabi came off the road in late august and i got back under the bonnet again for the next stage - and hired an engine crane again :smile:
Rain Stopped play briefly
Crane, check.
Health and safety suporvisor, check.
As you may be able to guess i could've done with more hands at this point, but where theres a will theres a way :smile:
Up......
And out :cool:
Not to shabby considering the muck it was pumping out the emissions breather
Always useful to have a bit of timber floating around :smile:
Guest El87cabi
Two weeks later i'm off to my friend Matts for him to strip down and access the bottom end damage
It appears no3 cylinder isn't all that well
Of course we have another health and safety supervisor on site to ensure everything is done correctly :wink:
Some rather manky pistons
In a rather grubby block.
Guest El87cabi
Now onto the section we needed to see.
I broke the cambelt pulley flange helping Matt get it off the crank :sad: took some heating but eventually it came free
Oil seals were eating into the crank both ends :sad:
Scored pretty bad :sad:
All done :cool:
Course of action being taken, Block being decked, faced and rebored to accommodate new 0.29 oversized pistons, crank is being ground to stage 1, crank, con rods, pulley, flywheel and clutch cover are being lighten/balanced. With luck i'll be collecting it all from Power Units later :biggrin:
  • 4 months later...
Guest El87cabi
Hey all, once again i've been snowed under with work, horse and home, at present i'm busily replacing my central heating from the boiler down while my horse is on box rest due to a puncture wound on his hock.
Loving every minute (not)
Neway, after Matt finding himself in need of a new fence after Dan backed into it, we decided to exchange our skills instead of cash so free fence build for free bottom end rebuild :cool:
I'm sure no one wants to see photo's of the bang up job i did on the fence so onto the engine pic's :biggrin:
Fresh new coat of paint not to mention the lovely new pistons :biggrin:
Now to refit n set the head to crank
And with the top on
Looking good even if do say so myself :biggrin:
Guest El87cabi
After transporting my 'precious cargo' home, i had to unload i, luckily after loading the engine before the rebuild, i had a cunning plan.......
Think the arse end of my car says it all really :cool:
All safe and sound, now just need to decide if i should have the box and diff done or just throw the whole lot back in :sleep:
Guest El87cabi
Thanks Ian and allblue, yeah thats was my thinking, get it done while its out, then i got some quotes, for the box i want i'm looking at between 800-1100 pounds :/
i have a lot of thinking to do, and not a lot of time to do it lol
  • 1 month later...
Guest El87cabi
Hey all, well the time has come to play everyones favourite game.......
Guess which bolt goes where lmao
may as well renovate the discs and callipers while i'm at it
Bit of surface rust
One chassis leg long overdue for a topcoat
Ready for spraying :smile:
Callipers painted but now rain has stopped play :sad:
Fingers crossed Saturday will be better
Guest El87cabi
Saturday arrived and even though the sky's were grey the rain held off :biggrin:
Engine bay received a polish
Chassis leg got a lick of paint and lacquer
And thanks to a hand from my good friend and neighbour Alan the box was mounted to the lump without too much agg :laugh:
That said i did get a tad ahead of myself
Anyone spotted what's not on the lump/box now?
Much spannering latter....
Loving the tree branch :cool:
Guest El87cabi
Thanks Welshy and Rs, it's taken a fair few years to get her this far and there's still a lot that needs attention
Bit more done today
Front panel's cleaned a bit then sprayed
alternators in and the bracket's been sanded and laquered
New headlamp adjuster fitted though i'm looking for the matching bolt/screw
Fitted the spotlight brackets i had floating about then went looking for some plugs to butcher in this
Found them :biggrin:
Guest El87cabi
Engine is now all back together (though i forgot A photo)
Decided to look into fitting the Trip Computer my cab was missing when i bought it
Nice to be back behind the wheel, that said i'm about to rip it off lol
And a few other bits
After a lot of digging around and looking at a spare loom i finally found the yellow plug i was looking for, unfortunately i also found the plug wires were trapped by a wire going through them after repair, found another, cut them both and retrieved the plug
Looks like soldering tomorrow
Guest El87cabi
Need to have the whole car done if truth be told but will have to wait a fair old while for that :sad:
Yes the bumper and bonnet are in storage while i figure out wth to do
