Guest neilseficab Posted May 8, 2016 Share Posted May 8, 2016 My 1990 efi has a job to idol and when driven at low speeds it feels like it has a misfire. Any ideas guys? Quote Link to comment Share on other sites More sharing options...
Guest username Posted May 9, 2016 Share Posted May 9, 2016 Not a huge amount to go on without more details if it does it when hot/cold/both, what's been checked/changed already or if there's any other symptoms. Also there is a diagnostic plug near the battery box/strut top area (black triangular plug, 3 pins) if you can get a code reader it'd maybe point something out. For what it's worth, ours had a similar sounding issue and sometimes stalled when coming to a stop and it was a bad connection to the coolant sensor (blue 2 pin plug on the thermostat housing, not the 1-wire gauge one nearby). The sensors themselves can go out of range too but start with simple stuff first Quote Link to comment Share on other sites More sharing options...
Guest blaughland Posted May 9, 2016 Share Posted May 9, 2016 I am getting something similar, but only when engine is warm. No bother when cold. When driving slowly (30mph in 4th gear) it is very chuggy! When idling it sits at approx 900rpm and has the occasional stutter. I will have a look at the connectors to ensure they are ok, but failing that I will take it for diagnostic checking. If that identifies the issue I will post answer. Whilst I am on, my electric hood goes down great but sometimes doesn't work when trying to put hood back up. No noise nothing, it's as though the switch is perhaps faulty. Any ideas? Thanks, Brian Quote Link to comment Share on other sites More sharing options...
zygott Posted May 12, 2016 Share Posted May 12, 2016 mine does exactly the same, had leads, plugs, coil pack, air temp sensor, checked cam timing, was out slightly, that improved it but its still there, im guessing i don't have the timing spot on yet. Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted May 13, 2016 Share Posted May 13, 2016 Hmm I've had this issue for years and have never sorted it really. Maybe thinking the camshaft is worn out? Quote Link to comment Share on other sites More sharing options...
Ian71 Posted May 13, 2016 Share Posted May 13, 2016 Worth checking as my efi fiesta turbo cost a fortune to repair when the cam lobes had worn so bad. If the engine feels realy sluggish then its time to investigate a worn cam. If engine has plenty of pulling power then chances are its not cam related. Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted May 13, 2016 Admin Share Posted May 13, 2016 ISCV ...Pain in the back side on the efi version :>( idle speed control valve . well worth taking off and giving it a clean with carb cleaner had many issues with mine ..cutting out at junctions bad idling when sat in traffic let us no how you get on regards Ollie Quote Link to comment Share on other sites More sharing options...
jinks Posted May 13, 2016 Share Posted May 13, 2016 hi had same problem i just fitted a superchip to the ecu and guess what runs alot better no flat spot and idles well Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted May 14, 2016 Share Posted May 14, 2016 Mine runs on base idle as the iscv never worked right. It still pulls nicely. As Ian and Ollie know after helping me put an Anglia alternator belt on at Santa pod lol Quote Link to comment Share on other sites More sharing options...
Ian71 Posted May 14, 2016 Share Posted May 14, 2016 Yea,fitted better than an original part lol Quote Link to comment Share on other sites More sharing options...
Guest neilseficab Posted May 30, 2016 Share Posted May 30, 2016 not tried changing anything yet, just wanted an idea before i started. I'm prone to the sort of problems that only ever seem to be sorted after trying many different things. It seems to idol reasonably ok when first started then once the auto choke cuts off it begins to idol rough and cuts out. It does have a slight misfire at around 2000 rpm but not sure if this is related or just another issue. Quote Link to comment Share on other sites More sharing options...
Guest username Posted May 30, 2016 Share Posted May 30, 2016 Check out Stephen's recent post on NGK vs Bosch spark plugs, could be worth a shot too Quote Link to comment Share on other sites More sharing options...
