Guest gavintwopies Posted July 31, 2011 Share Posted July 31, 2011 well looks like i might have a chance of a ib5 box fianlly with selector too. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted August 1, 2011 Share Posted August 1, 2011 Well as my alternator and bracket turned up this week i thought i'd give it a go fitting it just to see for clearance, Would you know its a good fit with a similar amount of clearance above and below the alternator. Quote Link to comment Share on other sites More sharing options...
Guest AstonB Posted August 2, 2011 Share Posted August 2, 2011 What mount is that exactly then? And is it standard CVH alternator? Looks ideal. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted August 2, 2011 Share Posted August 2, 2011 What mount is that exactly then? And is it standard CVH alternator? Looks ideal. Yes its the original escort cvh alternator and bracket just lowerd on the adaptor plate. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted August 10, 2011 Share Posted August 10, 2011 well finally after 2 birthdays and a wedding found time to make up my idler pulley wheel and bracket. 1st problem i had was the donor engine had this removed and was thrown in the bin inc the PAS pump (not by me) so had to struggle on trying to find one of them 1st. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted August 13, 2011 Share Posted August 13, 2011 well started to fit the ib5 gearbox again so swapped the flywheel to the smaller 1.6 zetec one then stuck the box on. If weather holds off i'll get a bit more done today. Quote Link to comment Share on other sites More sharing options...
gingergman Posted August 13, 2011 Share Posted August 13, 2011 some good work going on here still mate Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted August 13, 2011 Share Posted August 13, 2011 Rite well now for the proper mock up........ after getting a 1060pk6 drive belt today from halfrauds i tried the engine in to check all round for clearance issues and all looks sweet now. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted August 13, 2011 Share Posted August 13, 2011 Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted August 13, 2011 Share Posted August 13, 2011 Awesome Quote Link to comment Share on other sites More sharing options...
gingergman Posted August 13, 2011 Share Posted August 13, 2011 looking amazing Quote Link to comment Share on other sites More sharing options...
