Guest Graham Posted January 9, 2011 Share Posted January 9, 2011 (edited) Well guys you all no that i pick up a cabbie with a cracked block due to no antifreeze put in . The car had sat on the guys drive way for a year or so, when i picked her up she was like a swimming pool inside .Well today i went up to Paul's in Worcestershire to pick up a motor that he very kindly gave to me, its a EFI motor so am going to have to put my own head on her. Also i got the car out for the first today from picking it up and just dumping it off at mine on Monday , Still very wet inside also the boot carpet is like a sponge so that's now in the house drying off in the bath tub Tomorrow am going to strip the head of the spare motor and see whats that like , I also had a head gasket from Paul. I have sent for head bolts and valve steam oil seals and some other bits and bobs . Edited January 9, 2011 by Graham Quote Link to comment Share on other sites More sharing options...
Guest John Posted January 9, 2011 Share Posted January 9, 2011 looks a great motor fella Quote Link to comment Share on other sites More sharing options...
RScab Posted January 9, 2011 Share Posted January 9, 2011 Get it dried out ASAP m8 Look forward 2 more pics of the resto Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted January 9, 2011 Share Posted January 9, 2011 Like it Graham looks tidy As for the engine and gaskets glad i could help Quote Link to comment Share on other sites More sharing options...
Guest avul Posted January 9, 2011 Share Posted January 9, 2011 hi graham why do u need 2 put ur head on the efi engine? got my engine frm a local scrappy engine was frm a xr3i tin top, at the time they didn't ave a 1.6 carb & mine is a 1.3, so fitted it wiv a 1.4 carb, got out the timin light & set that up, ran sweet as! hope ya get it dried out quick & hope its as good as it looks m8, happy cabbie'in. Quote Link to comment Share on other sites More sharing options...
chaz Posted January 9, 2011 Share Posted January 9, 2011 Cab looks good mate. Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted January 9, 2011 Share Posted January 9, 2011 hi graham why do u need 2 put ur head on the efi engine? got my engine frm a local scrappy engine was frm a xr3i tin top, at the time they didn't ave a 1.6 carb & mine is a 1.3, so fitted it wiv a 1.4 carb, got out the timin light & set that up, ran sweet as! hope ya get it dried out quick & hope its as good as it looks m8, happy cabbie'in. Efi heads different to the mfi heads the inlet ports a totally different shape Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted January 9, 2011 Share Posted January 9, 2011 Thanks for saying what the difference in the two heads are Paul. If the weather is good tomorrow i will get it out put the roof down and let dry out a bit in the sun , I will also get some better photos of her and post some on here,Just looking forward to getting her ruining Quote Link to comment Share on other sites More sharing options...
Guest avul Posted January 9, 2011 Share Posted January 9, 2011 oh ok thanx 4 that as well paul, hope the weather's good 2moro 4 ya graham & the inside's ok 2.... Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted January 9, 2011 Share Posted January 9, 2011 Mines full of water too... Damn battery trays Think ill start a resto thread on mine when i get time Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted January 10, 2011 Share Posted January 10, 2011 Well the weather was to wet today to get the car out to dry here out , But i have taken the head of the spare motor that came with the car was very surprised to see the top of the piston very clean and the head was quite clean with no sludge and very little carbon on the valves, I have had the send for a valve spring tool as mine will not fit ,So as soon as that comes will nip the valves out for a regrind . Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 12, 2011 Share Posted January 12, 2011 nice mk3! strip the inside out, will dry quicker and you can give the floor a look over Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted January 12, 2011 Share Posted January 12, 2011 (edited) Will strip it out when i can get down there and get it our as the garage is small. , Well today my valve spring compressor came today so i have taken all the valves out , I did notice that on two exhaust valves that they both were missing a collet each ,The big question is where have they gone ? answers on a post card Edited January 12, 2011 by Graham Quote Link to comment Share on other sites More sharing options...
Guest jbh325i Posted January 12, 2011 Share Posted January 12, 2011 I did notice that on two exhaust valves that they both were missing a collet each ,The big question is where have they gone ? answers on a post card I had that experience with my mates A4 lately. I dropped the sump to change the oil pump and found 2 collet's the scary thing was the car ran sweet before this and is still running the same way bar a new oil pump. we've picked up a replacement lump but due to the good Scottish weather we've not went any further and hes running it still. Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted January 13, 2011 Share Posted January 13, 2011 Does make you think . Will this evening i ground the valves in did not take a look as they had been done not so long ago by someone , All lapped in fine so i then decided to polish the heads on the lathe , I found two that where few Tho bent so replaced then If i had not put then on the lathe i would have not known they where a bit bent ? Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted January 16, 2011 Share Posted January 16, 2011 (edited) Well today i did manage to get the cabby out to try and dry it out I have taken the seats out and the carpet the the underlay and carpet are wet threw ,they are now living in the bath to drain a bit as it raining here again arrrr I have had a look at the the floor and must say it 100 % solid and never had any welding done or needing any ,So very happy there . As in one of my posts i sad i had two collets missing form two of the valves i found one in the sump and bits of the the other one in the oil strainer not sure as where the other bits are as yet .I have put all the head back together cam in etc . Edited January 16, 2011 by Graham Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted January 17, 2011 Share Posted January 17, 2011 Well today i time to go down the garage and start to pull the old motor out , Took me most of the day to get the head off and all the rest of the stuff ,So now all that left to remove the old engine is to undo the bell hosing bolts and the engine mounts and its ready to pull. Quote Link to comment Share on other sites More sharing options...
chaz Posted January 17, 2011 Share Posted January 17, 2011 For a cab to have wet carpets for some time that floor is absolutley very solid, good luck with your work mate, hope you get some good weather to dry the carpets out, do you know where it is leaking from. Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted January 18, 2011 Share Posted January 18, 2011 She sat out side for a whole year so think it might be just that , Also with the snow we had, just think its the way it was parked up. But will look at it when she up and running Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted January 30, 2011 Share Posted January 30, 2011 She sat out side for a whole year so think it might be just that , Also with the snow we had, just think its the way it was parked up. But will look at it when she up and running Well today am manged to get down the garage and get the old motor out and yes i left the gearbox in place came out not to bad only a few scratches on the chassis rail nothing a bit of paint can cure Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted January 30, 2011 Share Posted January 30, 2011 I see you took my advice on lifting the engine straight out leaving the box in Coming on nicely now Graham Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted January 30, 2011 Share Posted January 30, 2011 Yes so glad i did leave the box in just hope its a easy to get back in Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted January 30, 2011 Share Posted January 30, 2011 nope no way your going to struggle!!! Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted February 2, 2011 Share Posted February 2, 2011 Cabbie looks nice and clean....as for putting engine back with gearbox in place rather you than me can be a right pain in the aRSe good luck....I went down this road with my mk4 in the P***ing down rain engine and box on the floor and lifted in together easier than trying to get engine and box mated in the car.. Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted February 2, 2011 Share Posted February 2, 2011 (edited) Piece of piss to get the engine back in with the gearbox already in all you need to do is jack the box up on an angle lower the engine in jiggle it about a bit and it will drop straight on to the spline takes all of 5 minutes Mind you i have been doing it this way since i was 15 and im 30 now so ive had plenty of practice lol Edited February 2, 2011 by paul xr2 Quote Link to comment Share on other sites More sharing options...
