Guest Janineskunk Posted September 14, 2016 Share Posted September 14, 2016 Hi all looking for some help any info greatly appreciated . We've had our cabriolet for approx 15 years now . It's a all blue se . Never had any issues until Saturday . Car has been garaged for a few years so we decided to get it out and back on the road . Car has always been started regularly , so after a new battery fresh fuel ,fuel filter,raidiator , exhaust, oil and filter change, and alternator plus other bits n bobs she was ready for mot . Took for mot on Saturday went to local filling station and filled with £20 of fuel travelled a couple more miles to mot station , was running perfect car was tested (passed no problem) . Taxed online after test . On way home about a mile from mot station it started to run terrible as if on 2 cylinders then cut out . Has not ran since. Changed plugs ,leads,crankshaft sensor but still no joy now has no spark any ideas anyone ?? Fuel is going to the rail all injectors are squirting fuel , pump is OK have drained out tank filled with more fresh fuel and another filter but still the same . any help greatly appreciated .... Quote Link to comment Share on other sites More sharing options...
jinks Posted September 14, 2016 Share Posted September 14, 2016 coil pack Quote Link to comment Share on other sites More sharing options...
Ian71 Posted September 14, 2016 Share Posted September 14, 2016 Take spark plug out and see if you have a spark. If not will be coil pack or crank shaft sensor Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted September 15, 2016 Share Posted September 15, 2016 Waiting for parts to be delivered hopefully should arrive today thanks Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted September 15, 2016 Share Posted September 15, 2016 Just wondering as its been stood a while. Has the heater matrix sprung a leak? It's right above the ecu. A soggy ecu will cause all sorts of problems Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted September 15, 2016 Share Posted September 15, 2016 Tried new ecu (the husband did) no change its sooo frustrating as I've just passed my test on the 8th August all this lovely weather will have gone by the time it's sorted ☹️ Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted September 15, 2016 Share Posted September 15, 2016 Thanks all Quote Link to comment Share on other sites More sharing options...
Ian71 Posted September 15, 2016 Share Posted September 15, 2016 Hope you sort it,let us know what the problem was. Regards Ian. Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted September 16, 2016 Share Posted September 16, 2016 Will do parts still not be delivered yet heard Royal Mail have been on strike Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted September 21, 2016 Share Posted September 21, 2016 Well new parts have been fit still no joy and now the indicators are not working but the hazards etc are still working ☹️️ Quote Link to comment Share on other sites More sharing options...
Ian71 Posted September 21, 2016 Share Posted September 21, 2016 Have you checked the fuse board ? Quote Link to comment Share on other sites More sharing options...
Paul Grainger Posted September 22, 2016 Share Posted September 22, 2016 Are you sure the injectors are pulsing? Were they checked using a noid is light? If so you can use the same thing on the coil pack wiring. There are three wires. The black one in the middle is the 12v feed from the ign relay. The two green ones are the earth trigger wires that go to the small edis 4 ECU on the bulkhead. Plug the noid light into the black and one of the green wires. Turn the engine over and see if it flickers. If it does then it is the coil pack. If not then it could be the edis 4 module or its related wiring. It does communicate with the main ecu using pip and saw signals which you can only test with a scope but don't worry about these. If the pip signal wire was broken then the injectors wouldn't be working and if you have lost the saw signal then the ign timing would be stuck at 10 degrees but should still start. Good luck Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted September 22, 2016 Share Posted September 22, 2016 Thanks Paul I'll pass this on to her husband 👍 Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted September 22, 2016 Share Posted September 22, 2016 *the husband Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted September 23, 2016 Share Posted September 23, 2016 My indicators packed up when a little black wire came off the battery. Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted October 2, 2016 Share Posted October 2, 2016 Update guys . Today I've had a multimeter to the crank shat sensor when turning the motor over it only showing 0.23 volts ..with the crank sensor out it shows no resistance I'm not great with electrics but this seems wrong to me I'm now thinking the new crankshaft sensor may be faulty , if I'm right would this stop spark and injectors?? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted October 2, 2016 Share Posted October 2, 2016 Crankshaft sensor not shat Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted October 2, 2016 Share Posted October 2, 2016 (edited) . Edited October 2, 2016 by Janineskunk Quote Link to comment Share on other sites More sharing options...
Ian71 Posted October 2, 2016 Share Posted October 2, 2016 Yes,mine recently would not start after I had done 30 miles,thought it was my immobiliser because I had no spark,checked everything else,rac man turned up unplugged sensor ,cleaned it and it started first time. Felt stupid cos it was the only thing I failed to check. Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted October 3, 2016 Share Posted October 3, 2016 Crank shaft sensor changed (again) still no joy !! Quote Link to comment Share on other sites More sharing options...
Ian71 Posted October 3, 2016 Share Posted October 3, 2016 Disappointing , what part of the country you live . Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted October 4, 2016 Share Posted October 4, 2016 A friend of mine has a fiesta turbo. She had a problem with a new sensor being slightly too short when compared to the original. Also when I swapped my gearbox once I damaged the crank sensor wire. Check for damage and conductivity with the multimeter. Quote Link to comment Share on other sites More sharing options...
Guest Janineskunk Posted October 4, 2016 Share Posted October 4, 2016 Crankshaft sensor and wire all ok as far i I can tell still no spark though . County Durham Ian Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted October 7, 2016 Share Posted October 7, 2016 Had any luck with it yet? Quote Link to comment Share on other sites More sharing options...
Ian71 Posted October 8, 2016 Share Posted October 8, 2016 Strange,the car ran ok then suddenley nothing in the way of a spark. Will have a word with a ford technician i know, he cut his teeth on cvh engines,does all my bits. Quote Link to comment Share on other sites More sharing options...
