Guest Kelly Jeffery Posted May 19, 2013 Share Posted May 19, 2013 hiya new here but i have just bought a white mk4 xr3i and looking to change the back seats to 2 front recaros ive had a nosie at some pics and seen that its been done i just need to know how to go about it all help welcome Link to comment Share on other sites More sharing options...
gingergman Posted May 20, 2013 Share Posted May 20, 2013 Hello, are you wanting to change the front or back seats? Link to comment Share on other sites More sharing options...
Guest Kelly Jeffery Posted May 20, 2013 Share Posted May 20, 2013 the back seats and put 2 front seats in Link to comment Share on other sites More sharing options...
Admin Ollie Posted May 20, 2013 Admin Share Posted May 20, 2013 easy job kelly have you got the seats already ? pics please Link to comment Share on other sites More sharing options...
gingergman Posted May 20, 2013 Share Posted May 20, 2013 Make sure the rear top part back rest of the seat is from a cabriolet as the tin tops are different. Only 4 10mm bolts holding each front seat in, two at the front and one each side, straight swap over and the rear seat base is on by two bolts under the hinge, pop the cover off and you'll see them, the back piece, pop the seat down using the pull in the boot and you'll see the hinges at the bottom, 3 torx head screws each side, if you ain't got star torx then some Allen keys will fit. Its all a straight swap that can be done in under a hour. Link to comment Share on other sites More sharing options...
RScab Posted May 20, 2013 Share Posted May 20, 2013 Think Kelly means puttin four Recaro front seats in stu 2 in the front & 2 on the back Link to comment Share on other sites More sharing options...
Guest Kelly Jeffery Posted May 20, 2013 Share Posted May 20, 2013 yea im wanting to have 4 recaros I have 2 kids and thought this looks good and helps with the seat belt problem I just need to know if I need to put thing in to strengthen the floor and if i need to chand the seats in any ? like the runners Link to comment Share on other sites More sharing options...
gingergman Posted May 21, 2013 Share Posted May 21, 2013 I initially thought this, but wasn't very clear, I've never seen it, don't personally see how its possible, if you was in the back you'd be sat very high! would take some seriously serious modification to work imo Link to comment Share on other sites More sharing options...
Guest Kelly Jeffery Posted May 21, 2013 Share Posted May 21, 2013 http://www.escortcabrioletclub.co.uk/forums/index.php?/topic/13433-pictures-wanted/?p=104156 its been done on one of these the 8th pic down number plate B BELL Link to comment Share on other sites More sharing options...
RScab Posted May 21, 2013 Share Posted May 21, 2013 You can lower the Recaro seats by stripping down the seat base & removin the small welded sections on the bottom the cover will then need to be shortened (doesn't look to bad a job) leaves the seat support mesh/rubber close to the floor but if there goin in the rear you may need to fabricate some fixin brackets anyway am shortening my recaro's in my Landie not finished yet tho Link to comment Share on other sites More sharing options...
Guest Kelly Jeffery Posted May 22, 2013 Share Posted May 22, 2013 thank you for the reply and a good bit of advise will shed more light on it when collet the car tomorrow http://s1308.photobucket.com/user/kelly_jeffery1/media/T2eC16JHJFoE9nh6mEuBRJmJSOrQ60_12_zps807d1b0e.jpg.html?sort=3&o=0 http://s1308.photobucket.com/user/kelly_jeffery1/media/T2eC16dHJGYE9noojiULBRJmuh0SP60_12_zps911aa421.jpg.html?sort=3&o=1 http://s1308.photobucket.com/user/kelly_jeffery1/media/KGrHqZHJEUFEjV6INnBRJmuVud1g60_12_zps11168559.jpg.html?sort=3&o=2 http://s1308.photobucket.com/user/kelly_jeffery1/media/KGrHqRHJFEFEklfUrhkBRJmuHG9g60_12_zps4cc4a608.jpg.html?sort=3&o=3 http://s1308.photobucket.com/user/kelly_jeffery1/media/KGrHqRHJEEFElCCoT0FBRJmu4gLCQ60_12_zpsb30959b1.jpg.html?sort=3&o=4 here she is Link to comment Share on other sites More sharing options...
Guest Kelly Jeffery Posted May 23, 2013 Share Posted May 23, 2013 shes home needs some tlc but was an experience for my first drive in an old car 160 mile journey home lol Link to comment Share on other sites More sharing options...
RScab Posted May 23, 2013 Share Posted May 23, 2013 Looks a nice clean motor Link to comment Share on other sites More sharing options...
Guest Kelly Jeffery Posted May 23, 2013 Share Posted May 23, 2013 she seems to be solid the battery tray needs replacing but its common an expected it im going to give her a good clean out see how easy it will be to sort the seats out but the mean time I need another back seat (the bottom peace) then think about a re-spray as its is a little shoddy Link to comment Share on other sites More sharing options...
danmk4escort Posted May 26, 2013 Share Posted May 26, 2013 car looks nice i like the whites ones had a thew in my days of cabriolets Link to comment Share on other sites More sharing options...
