Escort Diesel Engine
Guest no1birdman
  • 4 weeks later...
  • 2 months later...
  • 2 months later...
Guest no1birdman
my escort still sitting no engine yet, anyone no of a good diesel engine to put in, now wondering can i put a normal one back in without fuel injection, any size 1300 upwards, thanks.
Guest no1birdman
looking for a small petrol engine to now put in as cannot find a diesel, only been looking for nearly a year, 1.1. 1.3 petrol, anyone got one
  • 2 months later...
Guest no1birdman
well the engines i was promised never turned up, still looking for a diesel to put in,not been on road now for 12 months, cannot get one,every diesel ive looked at are no good,someone must have one, someone suggested a pug diesel.
the diesel engine i told you about is still available but will be getting binned shotly contact anth 07950940235. he may be able to deliver for a price
  • 1 month later...
  • 10 months later...
I have a 1.6 efi,its out of a very early mk5. Will be taking it out soon to replace with a zetec or rs2000. It can be seen running as it is still in the car. It also will have the wiring loom,ecu and gearbox attached. It also has power steering attached. I live in Bedfordshire.
  • 3 years later...
hi back again after a long time,old injury, eventualy  last week got diesel engine out up bank, then fitted the 1.3 fiesta engine, got it running nice  but a few electric problems, ie no ignition lights on dash,i wired starter ok off switch,wired coil off old glow plug relay feed , plugged alternator in no ignition light and no power to it from wire, no oil light and again no power to it, temp gauge not working,lights etc all work, its 20 odd years since i put engine and wired it up but i marked the wires i thought were right , buying another oil pressure switch as tested it and the terminal not going to earth as i thought the other one did, The problem is at 70 i cannot see the wires very well lol ,so anyone any ideas why no dash lights and no power  to them, if no luck might do it off the battery with switches and panel lights mounted somewhere , i altered a lot of wires when i did the diesel conversion.
