Guest Rustler Posted April 30, 2011 Share Posted April 30, 2011 Hi Guys. Am looking to replace the H/T leads on my 42k mls,'92 MK5 Escort 128bhp ZETEC Cabby. Any body got any views or advice on whether to buy cheapies or go for a dearer "Performance" set ? What do U run ,would you change for dearer or cheaper next time ? Which brand do U recommend? Thanks Rustler Link to comment Share on other sites More sharing options...
MarineIguana Posted April 30, 2011 Share Posted April 30, 2011 I'm using the Blue 8mm magnecor set on my RS after the standard ones kept giving a slight misfire now and then but that could have been due to the age of them, But I like to upgrade instead of replace and would buy them again anyday Link to comment Share on other sites More sharing options...
gingergman Posted April 30, 2011 Share Posted April 30, 2011 i use standard, but if your not botherd about the money side then id go for a better set, you might aswell upgrade when you can Link to comment Share on other sites More sharing options...
Guest Lee81 Posted April 30, 2011 Share Posted April 30, 2011 I have been down the route of expensive Ht leads and in all honesty its a waste of money. Most are actually worse than the standard ones. On the zetec they will work ok but wont see any gains. Its the older cvh engines where they cause interferance and lose you power. MSD sells HT leads at around £25 and they work as well as needed even on the old cabbys so can't argue with that. Link to comment Share on other sites More sharing options...
allblue Posted April 30, 2011 Share Posted April 30, 2011 For a standard spec Ford I'd stick to genuine ones. Can't go wrong and they last ages. Link to comment Share on other sites More sharing options...
iansoutham Posted April 30, 2011 Share Posted April 30, 2011 As long as you go for an 8mm or bigger lead you will be fine. Many of the "cheap and nasty" leads in motor factors and the like are 7mm, these will not supress interference and will break down quicker. I use Motorcraft 8mm leads on all my Fords and they work, even when pressure washing the engine bay with the engine running, no issues. You do that on a 7mm lead that is a year or two old and see how long it takes to get a mis-fire. Link to comment Share on other sites More sharing options...
Guest Eggsy Posted May 2, 2011 Share Posted May 2, 2011 10mm - sorted Link to comment Share on other sites More sharing options...
Guest Rustler Posted May 6, 2011 Share Posted May 6, 2011 Have just ordered a set of 8mm leads from "BURTON POWER", not the cheapest ,but postage to France was very reasonable, in fact the same price as a "BOSCH" set.........Will advise on performance later.... Thanks guys foryour input.. Link to comment Share on other sites More sharing options...
