Guest samrscab Posted February 25, 2011 Share Posted February 25, 2011 Looking good but i would deffo invest in a vernier pulley as the blocks are about 4mm taller than the cvh and this will knock your cam timing out by 1/2 a tooth, have you modded the engine mount yet? Also why not have a shot of running it on an edis4 & megajolt instead of a std dizzy that way when you get bored you can then drop a 2.0 zetec in. if you wanna keep it looking neat fit a 1.8 16v clio oilfilter there quite small and will give you loads of clearance. Also watchout for the oilfiler coming loose on the engine as its happended a few times to us cured it with a jubilee clip and a small length of an old arcwelding rod. hi thanks for comment..... i am looking into getting cash together for the pully, and yes mount got modified today so thats all good. and also was going to go down the route of mega jolt but have not got no more cash at min lol but defo will be doing that in the future. as for the oil filter you can get a long one or short one for that engine so i got 2 small ones (one for the first 2 days of running to catch any crap we couldnt get out, then change for the 2nd one) and do you mean the filler cap on the rocker cover?? if so i know what you mean lol cheers mate speak soon. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted February 25, 2011 Share Posted February 25, 2011 (edited) No, i was ment to say oil filter not filer the clio ones are a about 5cm long about 1/2 the length of a cvh one but with the roughness of the engine we have seen the filters vibrate loose even cvh ones, So wrap a big jubilee clip round it and clamp a 3mm or so rod to the filter and have it touching the edge of the back of the oilpump thus unable to vibrate loose. As for megajolt you dont need it straight away as the car will run on the edis4 with a static 10deg btdc till you get it. Edited February 25, 2011 by gavintwopies Quote Link to comment Share on other sites More sharing options...
Guest samrscab Posted February 26, 2011 Share Posted February 26, 2011 No, i was ment to say oil filter not filer the clio ones are a about 5cm long about 1/2 the length of a cvh one but with the roughness of the engine we have seen the filters vibrate loose even cvh ones, So wrap a big jubilee clip round it and clamp a 3mm or so rod to the filter and have it touching the edge of the back of the oilpump thus unable to vibrate loose. As for megajolt you dont need it straight away as the car will run on the edis4 with a static 10deg btdc till you get it. shall look into it mate and see what we can do the last thing i want is the filter bouncing down the road behind me haha and will definatly be looking into the mega jolt route, want to get my body work sorted before spend more on engine and bits haha speak soon mate. Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 26, 2011 Share Posted February 26, 2011 looking good mate, good to see you aint hangging around Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 6, 2011 Share Posted March 6, 2011 How it going with the zvh? Quote Link to comment Share on other sites More sharing options...
Guest benny Posted March 6, 2011 Share Posted March 6, 2011 sorry for my stupidity but whats megajolt and whats the benifts over the standard dizzy, ive got a 2.1 zvh with a fast road cam, and its a bit dissapointing, only 150 bhp with 101 lb torque, my pug has a 1.9 135 bhp engine with no cam and has 150 lb of torque! Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 6, 2011 Share Posted March 6, 2011 (edited) sorry for my stupidity but whats megajolt and whats the benifts over the standard dizzy, ive got a 2.1 zvh with a fast road cam, and its a bit dissapointing, only 150 bhp with 101 lb torque, my pug has a 1.9 135 bhp engine with no cam and has 150 lb of torque! The main benefit of megajolt is you are swapping to a waste spark system as fitted to all fords from 1990 onward 1st off you get a stronger spark but the best of it is you can map up the spark advance yourself via a laptop rather than rely on vacuum advance or very old electonic dizzy systems which again have mechanical failings such as dizzy caps and rota arms. Take a look on youtube for megajolt or take a look on one of the many sites catering for it such as: http://www.autosportlabs.com/megajolte-p-41.html?amp%3Bcurrency=GBP¤cy=GBP 150bhp and 101 lb/ft seems well low for such a torquey engine whats your engine set-up??? turbo n/a the 1st zvh i ever did came out at 175bhp 201 lb/ft out of a 1.8.... Edited March 6, 2011 by gavintwopies Quote Link to comment Share on other sites More sharing options...
Guest samrscab Posted March 7, 2011 Share Posted March 7, 2011 Hi all, its been a lil while but here are some pictures. engine in and bits going back together!! fuel pressure regulator just being fitted, with small inline fuel filter. carbs being fitted all very dirty again now lol will be cleaned though. bits going back on, now looking more like an engine haha. looking better carbs on bit of a cleaner picture. new filter for the carbs backing plate for filter to fit to, just got to cut and fit. thats all the updates for now but will keep updated as we go on. thanks Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted March 7, 2011 Share Posted March 7, 2011 Sweet Bet you can't wait to finish it Quote Link to comment Share on other sites More sharing options...
Guest samrscab Posted March 7, 2011 Share Posted March 7, 2011 Sweet Bet you can't wait to finish it your right there i cant wait haha. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted March 7, 2011 Share Posted March 7, 2011 Lookiing good m8. Think about fitting a oil separtor for breathing though. The CVH rocker cover is poorly baffled. You likly to get a lot of oil pumping out through that breather filter. Quote Link to comment Share on other sites More sharing options...
Guest samrscab Posted March 7, 2011 Share Posted March 7, 2011 Lookiing good m8. Think about fitting a oil separtor for breathing though. The CVH rocker cover is poorly baffled. You likly to get a lot of oil pumping out through that breather filter. thanks m8, will look into that tomorow. cheers. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 8, 2011 Share Posted March 8, 2011 not long now? would be interesting to get a before and after non megajolt and megajolt rolling road on this one. Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 8, 2011 Share Posted March 8, 2011 wow, looking awsome!! Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted March 8, 2011 Share Posted March 8, 2011 Hi, just finished reading this thread and agree looking well sweet! Some great info, thanks. Looking forward to seeing it finished. Quote Link to comment Share on other sites More sharing options...
Guest avul Posted March 8, 2011 Share Posted March 8, 2011 lookin gd sam dont 4get 2 get a vid up m8, my ear's r in need of an orgasm lookin 4ward 2 hearin that baby suckin & pumpin, lol gd progress 2 sam, bit jealous tho keep c'in all these cabbie's goin bak 2gether & mine's lossin more bit's, lol regards mark Quote Link to comment Share on other sites More sharing options...
Guest samrscab Posted March 9, 2011 Share Posted March 9, 2011 thanks for the replies everyone..... and mark i wouldnt be to jealous haha the amount of stress its caused, i have just brought a new accellerator cable for twin 40 webbers to put on instead of trying to modify the origanal cable. and it couldnt have been done without the help and know how of my mate. but with all the teething problems and other little probs i have been close to putting her on ebay a few times!! i shall keep the thread up to date whenever anything changes, and mark yes i shall get a video on as soon as she is all running nice and is tuned up. once she been run in a little bit i will try to get the money together to put her on the rolling road would be interesting to see what it comes out at just being: 1.8 bottom end 1.6 head r1 carbs keep you all posted. thanks again. Quote Link to comment Share on other sites More sharing options...
Guest benny Posted March 10, 2011 Share Posted March 10, 2011 (edited) The main benefit of megajolt is you are swapping to a waste spark system as fitted to all fords from 1990 onward 1st off you get a stronger spark but the best of it is you can map up the spark advance yourself via a laptop rather than rely on vacuum advance or very old electonic dizzy systems which again have mechanical failings such as dizzy caps and rota arms. Take a look on youtube for megajolt or take a look on one of the many sites catering for it such as: http://www.autosportlabs.com/megajolte-p-41.html?amp%3Bcurrency=GBP¤cy=GBP 150bhp and 101 lb/ft seems well low for such a torquey engine whats your engine set-up??? turbo n/a the 1st zvh i ever did came out at 175bhp 201 lb/ft out of a 1.8.... cheers for that dont think im technically minded enough though you lost me at mapping the spark advance! haha, mine is non turbo,2litre bottom end, running fast road cam, with 5th injector work magnex full system, with a k+n panel filter, still running on the old mfi injection, i think the power it made is rubbish! to be honest lol Edited March 10, 2011 by benny Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 22, 2011 Share Posted March 22, 2011 This must be up and running now? Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted March 22, 2011 Share Posted March 22, 2011 Very interested in any photo's of the twin webber set up, as thats the way I want to go!!!! Quote Link to comment Share on other sites More sharing options...
Guest samrscab Posted March 22, 2011 Share Posted March 22, 2011 This must be up and running now? yes haha been running the past few days now, need the carbs tuning, and few other niggly things doing but as cash is a problem at the min i have not been able to do much thats why the thread has not been updated. but yes she is running and drivable, i have to do nearside cv joint tomorow, and hopefully get the back plate for the pipercross filter back so that can go on. just everytime i replace something at the min something else goes wrong but the car was very neglected before i got her so it is time to start making her better. i will keep you all updated whenever i can. cheers Quote Link to comment Share on other sites More sharing options...
Guest samrscab Posted March 22, 2011 Share Posted March 22, 2011 Very interested in any photo's of the twin webber set up, as thats the way I want to go!!!! the only photos i have of the R1 carb set up at the moment are the ones in this thread i shall try get some better pictures over the next few days and put them on here for you. Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted March 22, 2011 Share Posted March 22, 2011 Cheers, appreciate that. Quote Link to comment Share on other sites More sharing options...
Guest donkey Posted April 8, 2011 Share Posted April 8, 2011 looks like a bit of work has gone into that my friend would love to have a look in the flesh so to speak Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted April 8, 2011 Share Posted April 8, 2011 (edited) looks like a bit of work has gone into that my friend would love to have a look in the flesh so to speak Yeah bike carbs get my vote everytime they have a rite deep throaty noise to them. Edited April 8, 2011 by gavintwopies Quote Link to comment Share on other sites More sharing options...
