Mark 4 Cabriolet Sills
zygott
hi
i believe the cabby is based on another body shell, but what one? i need a driver side sill for mine, someone has welded a poor quality cover sill onto it, im guessing they have jsut covered the rusty original one up.
it needs to be repalced. but what one do i get? i have seen them for a 2 door, a van and 4 doors but none for a cabby.
TBH most sills available are after market cover sills
The gauge most are made from is 0.9 & less than the original spec Ford sills
You can get some after market sills made from thicker material but not easy to find
You'll need to do some fabrication work on what ever sills you get as the lower support section
is a separate part - Have a look @ the following link
http://www.escortcabrioletclub.co.uk/forums/index.php?/topic/25434-escort-mk3-mk4-floor-sill-detail/
Cab Sills are basically the same as the 2 Door Tintop but will need to be modified
I needed a pair for my mk6. The only ones I could get were tin top ones which did not fit and were poor quality. Ended up fabricating new ones from sheet steel. She is double the weight she used to be but should outlast me!!
