Guest Philip Vowles Posted November 7, 2015 Share Posted November 7, 2015 I have a starting problem in that sometimes it will and another time it wont. It turns over but has no spark. Have tried the coil pack and the ignition pack to no avail. Tried the crank sensor and seems to be ok ( does similar to another one I had from another engine) but not 100% sure how to test it. Anyone got any ideas pleeease. Quote Link to comment Share on other sites More sharing options...
Ian71 Posted November 8, 2015 Share Posted November 8, 2015 Silly question but have you got an alarm fitted,as my efi fiesta sometimes wont start until i reset the alarm,failing that you need to do all the basics on electric supply, faulty earths,up to damaged leads,can be frustrating but usually something stuipid. Quote Link to comment Share on other sites More sharing options...
jinks Posted November 8, 2015 Share Posted November 8, 2015 I had same prob was the grey box on top coil pack clean all your earth ect Quote Link to comment Share on other sites More sharing options...
Guest Philip Vowles Posted November 9, 2015 Share Posted November 9, 2015 Did have an immobiliser fitted which i noticed was flashing strangely and thought that was the problem so removed it but is just the same. Will look at earths Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted November 11, 2015 Share Posted November 11, 2015 I had the same thing after I did a clutch. I had crushed the wire to the crank sensor...... Quote Link to comment Share on other sites More sharing options...
Guest Philip Vowles Posted December 16, 2015 Share Posted December 16, 2015 Found the problem, it was the crank sensor which had an intermittent fault.All fixed now! Quote Link to comment Share on other sites More sharing options...
