Guest gillyxr3i Posted June 14, 2015 Share Posted June 14, 2015 can somebody please tell me how i can open and close my roof, the hydraulic is all there and full of oil but cant seem to get it to go up and down on the button? many thanks adam Link to comment Share on other sites More sharing options...
Guest John Posted June 14, 2015 Share Posted June 14, 2015 sounds like probs with wiring. open boot on pump there ie a T on it open this it will allow u to open & shut it manually Link to comment Share on other sites More sharing options...
welshlad Posted June 14, 2015 Share Posted June 14, 2015 pop your hood switch out and try your passenger window switch in its place see if that works or obv check fuses and maybe wiggle green relays near the pump Link to comment Share on other sites More sharing options...
Ian71 Posted June 14, 2015 Share Posted June 14, 2015 Have you got ignition on, if so it wont open, you have to put key in and turn it to position 1 not ignition on. Link to comment Share on other sites More sharing options...
jinks Posted June 14, 2015 Share Posted June 14, 2015 is pump motor working if so you might need to bleed it Link to comment Share on other sites More sharing options...
Guest wolfetony Posted June 21, 2015 Share Posted June 21, 2015 I've got the same problem with my mk6 but just open manually till I can get a new pump was wondering is a mk6 pump the same as the mk6 Link to comment Share on other sites More sharing options...
