Mk4 Cabby Roof How To Open
Guest gillyxr3i
Guest gillyxr3i
can somebody please tell me how i can open and close my roof, the hydraulic is all there and full of oil but cant seem to get it to go up and down on the button?
many thanks
adam
sounds like probs with wiring. open boot on pump there ie a T on it open this it will allow u to open & shut it manually
pop your hood switch out and try your passenger window switch in its place see if that works or obv check fuses and maybe wiggle green relays near the pump
Guest wolfetony
I've got the same problem with my mk6 but just open manually till I can get a new pump was wondering is a mk6 pump the same as the mk6
