Moisture On Inside Of Windows
Guest Royv412
Guest Royv412
Hi guys,
Sorry if this has been asked previously, I've had a quick search through but didn't find an answer, i have noticed recently moisture has started appearing on the inside of the glass in my MK5b. The carpets are bone dry, checked right up to the pedals incase it was the hater matrix but bone dry, checked the boot again bone dry, I stuck a dehumidifier in the car for a couple of days and had about a litre of water in the catch can, next morning moisture all over the inside of the glass again.
Completely stumped, has anyone had this problem? I need to sort it as there have been signs of mould developing and I don't want the car getting ruined!
Cheers
Roy
Guest Royv412
It's outside, I did Havana a cover for it last winter but I've since lost it, it's not a daily drive, at this time of year I try and run it at least once if not twice a week
Right, i see , i have a couple of donor cars outside and they do suffer at this time of year wth exactly the same symptons as your car. Its the british weather i,m afraid unless you use them everyday or put them in a garage they will get damp inside and the seats do go a bit mouldy. I might be an idea if the weather is dry at the weekends to leave the windows ajar.
