badger Posted June 22, 2008 Author Share Posted June 22, 2008 well i thought i'd catch up and let everone know whats been going on with the cab. since instalation i couldn't get it to fire so first things first SPARK NO FUEL NO good start ? looked under dash and remembered there was no relays in holders so sourced some and hey i had both spark and fuel (get in there) but yet still wouldn't start. so after a little head scratching i decided to check timming and bugger me the bloke i brought engine from had only put inlet and exhaust cams on the wrong way round so striped it down and put them back and reset timing. still no start ERRRRRR so swapped everything i could think of ,edis,map etc etc NO NO NO BUGGER after another long talk to tony (thank god his about) i compression tested and NO all were good 155/155/155/165 after further investigation i found one injector not working so swaped it. still a big fat NO so today was check crankshaft sensor and apon getting it out OPPS it broke so that was it. i disconected everything and dropped the engine back out. i stripped gearbox off and took clutch off. and bugger me some idiot (the bloke i brought engine from) had only put flywheel back on in wrong position and could only get 5 of the bolts in, i also found that crankshaft seal was gone so there was a little oil in the bell housing so i stripped it out and i'll replace that and sump gasket while i'm at it. so the moral is don't buy an engine if you havn't heard it runing or you know and trust the person your getting it from. i'll get the camera back out and take some more photo's asap hopefully i'll be back on track soon. Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted June 23, 2008 Share Posted June 23, 2008 DOH !!! :wow: Shame about that but seems like you found the prob mate !!! This Topic is living up to its name, SCRACHY HEAD TIME, not half lol !!! Keep us posted bud !!! :icon_salut_gb: Link to comment Share on other sites More sharing options...
Guest micxr3i Posted June 24, 2008 Share Posted June 24, 2008 is this a conversion from an mfi engine to zetec? Link to comment Share on other sites More sharing options...
badger Posted June 24, 2008 Author Share Posted June 24, 2008 is this a conversion from an mfi engine to zetec? sort of, i had the cvh 1.6 carb in so if you go back and read the whole post you'll see i had to change everthing including petrol tank /lines ,wiring loom,etc etc. Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted June 24, 2008 Share Posted June 24, 2008 ok so ....... looks like the engine was a vegtabal lol well glad you sorted it been scraching me head lol ............. shouldnt be long now Link to comment Share on other sites More sharing options...
Guest micxr3i Posted June 24, 2008 Share Posted June 24, 2008 (edited) sorry must have missed it im not clued up on engines so to change the mfi to zetec will i need to change my tank, fuel lines, radiator? and can i use a mk4 efi wiring loom on the 2ltr zetec? sorry for hi jacking your thread Edited June 24, 2008 by micxr3i Link to comment Share on other sites More sharing options...
badger Posted June 25, 2008 Author Share Posted June 25, 2008 sorry must have missed it im not clued up on engines so to change the mfi to zetec will i need to change my tank, fuel lines, radiator? and can i use a mk4 efi wiring loom on the 2ltr zetec? sorry for hi jacking your thread you will need to change wiring loom for efi or go aftermarket ecu but fuel side is fine and so is rad you just have to do a few little mods and thats it the mk4 loom is the best from what i'm told but tony is the main man on these and has been a real help to me but if you need any help just ask and if i can't help i'm sure there will be someone who can Link to comment Share on other sites More sharing options...
Guest micxr3i Posted June 25, 2008 Share Posted June 25, 2008 cheers mate will do Link to comment Share on other sites More sharing options...
badger Posted July 21, 2008 Author Share Posted July 21, 2008 ********************************************NEWSFLASH*************************** ************************ We have power, it started at long last..yipeeeeeee. so now its back together with suspension/brakes/driveshafts etc etc and of to powerflow to have exhaust fitted. nearly time to get her on the road. Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted July 23, 2008 Share Posted July 23, 2008 Nice one mate, keep us posted, any new pics ??? Link to comment Share on other sites More sharing options...
badger Posted August 3, 2008 Author Share Posted August 3, 2008 well here's some pictures for you to look at but things are not great i have lost the spark and i'm having alot of trouble locating the fault but i'll get there but i do need to get it started before the 11th as it's booked in for the exhaust to be fitted. http://i270.photobucket.com/albums/jj104/badger180/017-1.jpg http://i270.photobucket.com/albums/jj104/badger180/019-1.jpg http://i270.photobucket.com/albums/jj104/badger180/021.jpg Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted August 4, 2008 Share Posted August 4, 2008 Look cool them brakes mate !!! Link to comment Share on other sites More sharing options...
badger Posted August 31, 2008 Author Share Posted August 31, 2008 well just a quick update i have had exhaust fitted £280 from manifold back in stainless from powerflow (sounds a little loud but i'm well happy) car has mot but have a few teathing problems i think head gasket isn't right as it boils over before fan switch comes on and it seems bloody hot under bonnet but i'm running the fan all the time so i can use it. then the other day the drive shaft poped out (not 100% sure if it was in right to start, but 95% sure it was so think it poped out under load) it does worry me ????? does anyone know if you can upgrade the drive shafts ?????? i have also changed the interior for a 90's spec interior. and will post some more pictures soon. Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted September 1, 2008 Share Posted September 1, 2008 You have been busy mate, looking forward to seeing the new interior, do a video of the exhuast and whack it on YouTube so we can hear it !!! Link to comment Share on other sites More sharing options...
chaz Posted September 1, 2008 Share Posted September 1, 2008 Looking good mate. Link to comment Share on other sites More sharing options...
Guest markeyboy Posted September 1, 2008 Share Posted September 1, 2008 havnt been following this one very well, uv done a great job with this one mate, well done not sure about uprated shafts (sure u could new ones made at a cost) new ones from ur local car spares that may hold in a bit better but it may have been a one off and now uv put it bk itl be ok Link to comment Share on other sites More sharing options...
badger Posted September 1, 2008 Author Share Posted September 1, 2008 lets hope so marky the cv joints on a mk4 1.6 are all the same (turbo or non turbo)so there shouldn't be a problem there i might have a weak clip on driveshaft so i think i'll get new ones from fords and refit them again. fingers crossed... Link to comment Share on other sites More sharing options...
badger Posted September 21, 2008 Author Share Posted September 21, 2008 well here you go, just some more photo's to keep you posted. i have put newer interior in and there is a picture of rear end with new exhaust exit on, next time she's up in air i'll get some better pics. i've brought 30mm lowering springs and gaz shocks i am also looking at uprated gearbox mounts and i'm going to strip head down to try and find the boiling over problem, so i've purchased all the seals and gaskets for that. i still don't trust her so i'm not taking her out to far and will spend the winter doing the above plus electric roof and rear poly bushes which i allready have in the garage. its all go, but i love it (the mrs isn't impressed but sod her it's my toy) Link to comment Share on other sites More sharing options...
badger Posted September 21, 2008 Author Share Posted September 21, 2008 (edited) i'm not sure if this will work or not but i thought it was worth a try. sorry it didn't work just forget this post Edited September 21, 2008 by badger Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted September 25, 2008 Share Posted September 25, 2008 Bout time you put up some pics, was starting to forget what it looked like PMSL !!! :happy001: Lookin' nice and clean there mate, hows she running nowdays ??? Link to comment Share on other sites More sharing options...
badger Posted December 10, 2008 Author Share Posted December 10, 2008 (edited) well another quick update after driving it for a while and ironing out some problems from drive shafts poping out to overheating, i just started to trust it and go further afield. but i did find that the exhaust was a little to loud, it was ok around town but a real dronne on long trips so went back to power flow and had another box fitted which also improved the bottom end pulling power the zetec must need the back pressure, so not to bad then on the way home the clutch started playing up and i now have a massive amount of clutch judder at the bite point and will have to wait till xmas to drop box of again and have a look i wouldn't mind but put the rs turbo clutch in to start with. mind you i will do the 30mm lowering while its up on stands and a little bit of painting as well so lets hope for a couple of dry days. Edited December 10, 2008 by badger Link to comment Share on other sites More sharing options...
chaz Posted December 11, 2008 Share Posted December 11, 2008 Good to see the cab is getting some use mate, shame about the clutch but it's nothing abnormal. Link to comment Share on other sites More sharing options...
badger Posted January 4, 2009 Author Share Posted January 4, 2009 hello again people just a quick update,over the cold holiday i striped the gearbox off and took out clutch and exchanged it at our local motor factors but couldn't see a lot wrong with it,anyway they exchanged it and i fitted the new one and hey presto no more clutch judder and while i was about it i fitted new gaz shocks with 30mm lowered springs and heres a couple of photos. next job is to do the back end i've got poly bushes and lowering kit to do so hurry up the warmer weather. Link to comment Share on other sites More sharing options...
Guest markeyboy Posted January 5, 2009 Share Posted January 5, 2009 thats good mate, you should notice the difference in handling, especially once ya polybush the rear, get some pics of how the car is sitting now ya lowered it Link to comment Share on other sites More sharing options...
