Guest diane Posted August 8, 2007 Share Posted August 8, 2007 ok when someone knows what they are doing they can come and do mine lol !!! Link to comment Share on other sites More sharing options...
Guest diane Posted August 8, 2007 Share Posted August 8, 2007 oops sig pic abit too big !! lmao Link to comment Share on other sites More sharing options...
Guest 6tracy9 Posted August 8, 2007 Share Posted August 8, 2007 YEah and when u've done di's u can come and do mine!!! OMG Di is ur sig big enough!!! LOL!!! Link to comment Share on other sites More sharing options...
Guest sjc Posted August 8, 2007 Share Posted August 8, 2007 i'll come! Link to comment Share on other sites More sharing options...
Vincygav Posted August 15, 2007 Share Posted August 15, 2007 It is not illegal to run the hood when driving as someone mentioned earlier in this post. Other manufacturers allow the roof to be taken done whilst driving, like Saab etc. although they have inhibitor switches set at 20 or 30mph. As for the location of the yellow relay, put your head on the floor and you would see it near the central locking control module. It is next to a green relay. Link to comment Share on other sites More sharing options...
Guest Matt_Norwich Posted August 15, 2007 Share Posted August 15, 2007 Mark you sussed it yet mate? and if so what did you have to earth out? , going to mine next Link to comment Share on other sites More sharing options...
Guest dangerousdave28 Posted August 15, 2007 Share Posted August 15, 2007 Mark you sussed it yet mate? and if so what did you have to earth out? , going to mine next I then fitted a bypass so I can operate the roof with the engine running. The wiring is different on the late mk6, so if anyone wants to do it, heres how. Next to the battery is a connecter with 1 blue wire going into it, disconnect it and close the bonnett. Then remove the drivers kick panel and find a blue and red wire taped together. I used a scotch lock and connected the blue wire to a switch, the other terminal on the switch is connected to an earth. That's it, with the switch off the roof dosen't work flip the switch and it will work with ignition on and engine running. You don't the switch, I just did it as a safety method. If you don't use a a switch, just earth blue wire in the footwell and make sure you unplug it near the battery. Dave Link to comment Share on other sites More sharing options...
Guest markeyboy Posted August 15, 2007 Share Posted August 15, 2007 Mark you sussed it yet mate? and if so what did you have to earth out? , going to mine next i havnt got round to it yet m8, will report bk on how it goes when i do it Link to comment Share on other sites More sharing options...
Guest Jay-3i Posted August 20, 2007 Share Posted August 20, 2007 It is not illegal to run the hood when driving as someone mentioned earlier in this post. Other manufacturers allow the roof to be taken done whilst driving, like Saab etc. although they have inhibitor switches set at 20 or 30mph. As for the location of the yellow relay, put your head on the floor and you would see it near the central locking control module. It is next to a green relay. just tried it on the mk4 it works!!! yess!! it wont do it any harm will it!? i always thought it was stupid having the roof work while its not running, it doesnt half drain the battery Link to comment Share on other sites More sharing options...
Guest sjc Posted August 20, 2007 Share Posted August 20, 2007 figured out what the two saftey switches are, they are conneted to the press studs that the tonneau clicks onto, so you cant operate roof with it on Link to comment Share on other sites More sharing options...
Guest dangerousdave28 Posted August 20, 2007 Share Posted August 20, 2007 figured out what the two saftey switches are, they are conneted to the press studs that the tonneau clicks onto, so you cant operate roof with it on Looks like they've been disconnected in my cab and the wires earth instead. That's another mystery solved. Link to comment Share on other sites More sharing options...
