DaveH Posted July 2, 2017 Share Posted July 2, 2017 Hi there. when replacing the rear tie bars on a mk4 is it necessary to have the rear wheel alignment checked and adjusted? Thanks. Quote Link to comment Share on other sites More sharing options...
iansoutham Posted July 5, 2017 Share Posted July 5, 2017 Technically yes. However, most tracking places are run by monkeys who do not know one end of a measurement from the other so will tell you that it is not adjustable. To adjust it, you need the appropriate washers as they are the shims to set it up. To do it correctly takes time. Quote Link to comment Share on other sites More sharing options...
DaveH Posted July 5, 2017 Author Share Posted July 5, 2017 ok thanks, i was a bit confused because there is a torque wrench setting for the nuts at the wheel end ! and the washers are understandably very rusty. Quote Link to comment Share on other sites More sharing options...
Paul Grainger Posted July 8, 2017 Share Posted July 8, 2017 Sadly Ian is absolutly right. Most don't have a clue or couldn't be bothered!!! It's not the torque setting that adjusts it. It is the position of the washers on the tie bar i.e. before or after the suspension unit as this moves its lower position. It's a bit primitive but makes a big difference especially to tyre wear. Good luck. Quote Link to comment Share on other sites More sharing options...
