Nick Barnes Posted January 27, 2017 Share Posted January 27, 2017 Hi silly question but where is the lights on buzzer located ? the buzzer that sounds when you open the door and your exterior lights are on ? mine works sometimes, sometimes not ? sometimes it starts buzzing then stops ? what's the problem do you think ? the buzzer or the connection to the door switch ? the interior light works when you open the door, so the door switch is working properly ? so I'm thinking connection to the buzzer from the door switch maybe ? or where it connects to the lights ( so it knows if they are on or off ) ? Any one had this and what was the solution ? Cheers Nick Link to comment Share on other sites More sharing options...
Guest username Posted January 28, 2017 Share Posted January 28, 2017 Not sure where the buzzer is located, but it could still be a flaky door switch connection (the interior light being on a timer probably wouldn't show it up as much). At least it was this way on my old Sierra. Try wiggling the pin of the door switch and see if it affects how the buzzer works. Link to comment Share on other sites More sharing options...
Vincygav Posted February 6, 2017 Share Posted February 6, 2017 Buzzer is located behind the dashboard on the drivers side. Link to comment Share on other sites More sharing options...
Nick Barnes Posted February 7, 2017 Author Share Posted February 7, 2017 cheers Si I sprayed the door switches and its OK ATM but now I know where it is for future problems Link to comment Share on other sites More sharing options...
