Guest baz9707 Posted October 10, 2016 Share Posted October 10, 2016 I recently changed my radiator and cleaned the starter motor to do this I moved the alternator now the belt whines and the battery light is on. I have moved it forward as far as it goes to make it taught. The alternator is only a year old. Quote Link to comment Share on other sites More sharing options...
jinks Posted October 12, 2016 Share Posted October 12, 2016 remove belt and spin the alternater you will here it if the bearing has gone or your belt needs replacing Quote Link to comment Share on other sites More sharing options...
jinks Posted October 12, 2016 Share Posted October 12, 2016 also I think its got a brush on there cant remember could be worn Quote Link to comment Share on other sites More sharing options...
dalem2 Posted June 5, 2017 Share Posted June 5, 2017 streached belt-----wont take uk play Quote Link to comment Share on other sites More sharing options...
Ian71 Posted June 5, 2017 Share Posted June 5, 2017 Change the belt,will tell you strait away Quote Link to comment Share on other sites More sharing options...
