Guest 2steppa Posted December 16, 2015 Share Posted December 16, 2015 (edited) Hi all. My cabby has been running pretty good lately (apart from the rear trailing arm snapping!) but tonight I was just setting out and after about 10 minutes of running fine doing about 50 and it just stops - nothing, no power like it's run out of fuel...... (It has half a tank full btw). I try to start it the fuel pump makes the usual whirr and it fires gets no higher than 1000 rpm makes a few backfire bangs and stops. Any ideas what may have suddenly happened? Cheers. Edited December 16, 2015 by 2steppa Quote Link to comment Share on other sites More sharing options...
Ian71 Posted December 16, 2015 Share Posted December 16, 2015 Silly question but gotta ask first,did you recently fill up with fuel,if so are you sure you did,nt put diesel in ? Quote Link to comment Share on other sites More sharing options...
Ian71 Posted December 16, 2015 Share Posted December 16, 2015 If not that have you checked all the leads from the coil pack to the spark plugs, gotta do all the basics first realy Quote Link to comment Share on other sites More sharing options...
Guest 2steppa Posted December 16, 2015 Share Posted December 16, 2015 Hi, No, recently (today) put some super unleaded in but definitely used the right pump! (easy mistake I know) It's weird it was running perfectly no hints of a problem or lumpiness and suddenly........ gone. Like I say it will start and run up to 1000 ish rpm but throttle won't push it any higher it's banging and spluttering and then dies out and stops. Is it likely that the fuel line or filter is blocked or is that uncommon? The pump sounds the same as ever, but could it be priming but not running on? I'm not much of a mechanic so excuse my ignorance :-) Quote Link to comment Share on other sites More sharing options...
Guest 2steppa Posted December 16, 2015 Share Posted December 16, 2015 I'll have to get it towed to the garage in the morning, and fingers crossed fixed by the weekend.. Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted December 16, 2015 Share Posted December 16, 2015 I've got a chip plugged into my ecu, it came loose once and was just hanging out. That caused it to die and pop and bang when it was running. If not like Ian said, plugs, leads, coil pack, wrong fuel. Check around the fuel rail for some small vacuum hoses. Then check the timing marks for piece of mind. Quote Link to comment Share on other sites More sharing options...
Guest 2steppa Posted December 18, 2015 Share Posted December 18, 2015 OK seems it's the fuel pump again - now I need to try and get hold of the in-tank pump/sender unit. Not an easy task it seems :-( Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted December 18, 2015 Share Posted December 18, 2015 I've had numerous problems with my pump. If its the seals in the flexible thing between the pump and the metal pipe get rid of it and put a piece of fuel hose in place. I did this and it's fine. I also had the black box pop on the underneath of the metal plate. I disconnected it and soldered and heat shrunk the wires to the pump wires. Again it's fine lol Quote Link to comment Share on other sites More sharing options...
Ian71 Posted December 19, 2015 Share Posted December 19, 2015 Is yours a mk5 1.6 cvh if so i managed to get a new in tank pump for mine. Let me know and i will dig out the details,it was quite reasonable in price to, i think a ford one was £300 if you could still by them, but i think i only paid £50 or less. Quote Link to comment Share on other sites More sharing options...
Guest 2steppa Posted December 19, 2015 Share Posted December 19, 2015 Mines a MK4 1990 on a G plate - I need the whole sender / float / pump assembly and can't seem to locate one anywhere :-( If I can't get one then that's it - the car will be sold for resto or parts as a non runner which would be criminal given the condition of it, Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted December 19, 2015 Share Posted December 19, 2015 Who has said that the pump is the problem? The symptoms you describe don't sound like a pump problem to me. Have you taken the fuel pipe off the regulator to see if there is any pressure? Mines a 90 on a "g". And it's turbo'd now with the same pump I described previously. Don't want you to end up breaking it if it can be mended. Quote Link to comment Share on other sites More sharing options...
Guest 2steppa Posted December 20, 2015 Share Posted December 20, 2015 The garage said it's the pump, it pumps when you start from cold and then the flow becomes erratic the longer it's left running. It did make a louder than usual whirring sound a while back whilst it was running which it didn't normally do, only when you turn the key on. It was making a 'singing' whirring sound while the engine was running and the switch on priming sound had changed sometimes a healthy buzz and sometimes a laboured grind. Here is the old gal - would be a shame as you say. Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted December 20, 2015 Share Posted December 20, 2015 By the sounds of it you don't need the whole pump set up. Only the pump itself. This can be removed and an aftermarket or secondhand pump from a mk5 or 6 fitted in place. Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted December 20, 2015 Share Posted December 20, 2015 Xr2i and fiesta turbo ones are the same as well Quote Link to comment Share on other sites More sharing options...
Ian71 Posted December 20, 2015 Share Posted December 20, 2015 Try this ebay no 351178057921 not the one i bought but similar,give em a call to see if its compatable ? Quote Link to comment Share on other sites More sharing options...
Guest 2steppa Posted December 20, 2015 Share Posted December 20, 2015 I'll have a look but the garage seem to think the existing one has been bodged to use a different pump in the past and as a result the proper one that arrived is no longer suitable!!! A right royal pain. Quote Link to comment Share on other sites More sharing options...
Ian71 Posted December 20, 2015 Share Posted December 20, 2015 Might be worth having a look for a replacement tank with pump still in(second hand) Quote Link to comment Share on other sites More sharing options...
Guest 2steppa Posted December 20, 2015 Share Posted December 20, 2015 Good idea Ian. The pump/sender complete unit seems impossible to locate on it's own. Quote Link to comment Share on other sites More sharing options...
Ian71 Posted December 21, 2015 Share Posted December 21, 2015 Give Maido a pm, he may have one,breaks cabs for a living. Quote Link to comment Share on other sites More sharing options...
