Guest Buyandsellperc Posted October 11, 2015 Share Posted October 11, 2015 Hi all. Not long had my rs cab and spent a small fortune on bits and pieces. Anyway, i did an oil and filter change on friday and left it to drain overnight. Refilled and attempted to start it up saturday morning and it sounded like a subaru. Shaking engine, misfiring massivly and chugging out black smoke. It wouldnt idle at all. This morning it wont even start up at all. Ive checked spark plugs, leads. Theres a good spark from all 4. Group a coil fitted and its all good. Its an mfi rs turbo engine. The injectors are all spraying fine, the fuel pump is priming. Havent got a clue why its all of a sudden gone from running perfect to misfiring and not even starting? The oil i removed was well sticky too. Like a glue type feel to it and it stinks of petrol too. Could a previous owner added some sort of additive to mask a knackered engine? Im seriously at a loss with it. Please help. Steve Quote Link to comment Share on other sites More sharing options...
Ian71 Posted October 11, 2015 Share Posted October 11, 2015 Was the engine running ok before hand,was it slightly mis firing ? have you removed the sump or just the drain plug ? Quote Link to comment Share on other sites More sharing options...
Guest Buyandsellperc Posted October 11, 2015 Share Posted October 11, 2015 It was running fine before hand. No misfire at all. I drained the old oil out with the drain plug. I didnt remove the sump. Quote Link to comment Share on other sites More sharing options...
Ian71 Posted October 11, 2015 Share Posted October 11, 2015 If it was running fine cant see why changing the oil should spark off a change in the engines running,might just be a coincedence and is now something electrical or a vacum pipe come off or leaking,oil thats thick might be a aditive for a old engine or worse sludge from a camshaft thats worn, sorry but i cant realy put a finger on why that should suddenly change so drastically. Good luck. Quote Link to comment Share on other sites More sharing options...
jinks Posted October 12, 2015 Share Posted October 12, 2015 might have a dodgy fuel filter Quote Link to comment Share on other sites More sharing options...
