Guest baz9707 Posted June 8, 2015 Share Posted June 8, 2015 I need to cut my emmisions on my mk4 escort cabriolet. I am replacing the manifold gasket and bolts. Just wondering whag is the best additive. I heard a few of ghem mess up old cars. Any help appreciated. Baz Quote Link to comment Share on other sites More sharing options...
jinks Posted June 8, 2015 Share Posted June 8, 2015 hi baz is the co to high Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted June 8, 2015 Admin Share Posted June 8, 2015 efi model baz ? Quote Link to comment Share on other sites More sharing options...
Guest baz9707 Posted June 8, 2015 Share Posted June 8, 2015 Its a mfi noticed 3 bolts have sheered where the manifold connects to the exhaust. Any ideas where I can get these bolts from. Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted June 8, 2015 Admin Share Posted June 8, 2015 the studs you should be able to get them from any motor factors baz Quote Link to comment Share on other sites More sharing options...
Guest baz9707 Posted June 8, 2015 Share Posted June 8, 2015 Cheers going to get up early before work and attemp to prise them out god knows how lond theh have been like that. Anyone had any joy with the additives for reducing emmisions and increasing performance. Quote Link to comment Share on other sites More sharing options...
Guest baz9707 Posted June 8, 2015 Share Posted June 8, 2015 The bushes on the fuel pump bracket have gone and its a bit loose not many of these about will try and find a solution. Quote Link to comment Share on other sites More sharing options...
Guest baz9707 Posted June 11, 2015 Share Posted June 11, 2015 Cracking found the bolts and anti vib part on ebay. Hope it arrives soon Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted June 12, 2015 Share Posted June 12, 2015 A few sheered bolts on the exhaust is unlikly to cause high co. The co can be adjusted on the metering unit. Before doing so make sure to check the vacuum advance diaphram on the distributor isn't leaking. This will cause high rising co at idle. Also that you have new plugs,cap and rotor arm ( Only last around 6000 miles in some cases but are very cheap) Air leaks on inlet side will be more likly to cause low co and detonation so i doubt theres any major ones there. Be aware once you've get co in tolerance of any rattling when under load higher up rev range ( Detonation ) Most people bodge the MFI unit by setting co high at idle so higher up rev range it doesn't run lean. What is common is the spring that controls fuel pressure to get weaker over time. This causes lower fuel pressure. This can be adjusted by adding copper shims to the back of the spring to raise fuel pressure back to where is should be. Not many people will know how to do this. The shims are only 0.01mm thick and small increases make big changes to fuel pressure. Doing this will also work wonders for cold starting and improve all aspects of running. Most have never had this done. Quote Link to comment Share on other sites More sharing options...
