Guest Andrewgibbs27 Posted June 1, 2015 Share Posted June 1, 2015 Need some advise please. My escort cab was sat for 5 years, now trying to get running. Have drained old fuel, put fresh fuel inand put new battery in, turns over but doesn't start. Advise where to go next?? It's a f reg cabriolet, Thankyou Quote Link to comment Share on other sites More sharing options...
Ian71 Posted June 1, 2015 Share Posted June 1, 2015 Does the fuel pump make a noise when you turn ignition on, if not might be fuel pump. If ok gotta be electrical, have you got spark going to plugs ? Quote Link to comment Share on other sites More sharing options...
Himanshu Posted June 2, 2015 Share Posted June 2, 2015 turn the car over and check if the spark plugs are damp and smell of petrol. If so the check the spark is there. If the spark is not there, check for a spark at the coil. You will deduce if it a fuel starvation problem or electrical one. But before check the cambelt has not perished or broken. Just renew if you know how. then turn the engine over by hand. Quote Link to comment Share on other sites More sharing options...
