welshlad Posted May 26, 2015 Share Posted May 26, 2015 Hi guys Refitted engine/box and roll bar and now near/passenger side ball joint is a couple of cm off being able to fit it. drivers side went in straight away took me a few seconds, Ive tried unbolting tca and then fitting ball joint but then the tca bolt wont go back to refit that Also ive tried slackening the antiroll bar and mounts and thats no help Any ideas??? been trying for hours if the inner cv joint wasnt fully inserted into the gearbox id think it was that but its def in Quote Link to comment Share on other sites More sharing options...
StuDaBear Posted May 26, 2015 Share Posted May 26, 2015 has the anti roll bar been right off? Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted May 26, 2015 Share Posted May 26, 2015 If it has it sounds like you may have put it back on upside down Quote Link to comment Share on other sites More sharing options...
welshlad Posted May 26, 2015 Author Share Posted May 26, 2015 its had mounts off to put new rubbers on and then off at the mounts to take engine box/out so its not that..... it looks as if the gearbox need to go to the left a bit more so theres more clearance but i cant see how i can get it move without unbolting everything, and obv i shouldnt have to do that Quote Link to comment Share on other sites More sharing options...
welshlad Posted May 26, 2015 Author Share Posted May 26, 2015 any chance its been put on wrong before, and its only pure luck that ive got the ball joints on in the past? im proper confused by it its give me a headache literally Quote Link to comment Share on other sites More sharing options...
RScab Posted May 26, 2015 Share Posted May 26, 2015 Tony release the front mounts Fit the arms then jack up the center of the ARB and fit the front mounts Quote Link to comment Share on other sites More sharing options...
welshlad Posted May 27, 2015 Author Share Posted May 27, 2015 (edited) tried that, and unbolting gearbox cradle , the hub just needs to go inwards e few mill and then it will pop in as its supposed to also tried loosening front gear box cradle bolts, and prying gearbox at same time, run out of options at moment Edited May 27, 2015 by welshlad Quote Link to comment Share on other sites More sharing options...
welshlad Posted May 27, 2015 Author Share Posted May 27, 2015 Sorted!! had to fully take the ARB out of the TCA and then wiggled the ball joint into the hub carrier Still tho ive never had problems before so why have i had to do it this way??? hmmmmm Quote Link to comment Share on other sites More sharing options...
