Admin Ollie Posted July 5, 2013 Admin Share Posted July 5, 2013 hi all the sister inlaw has a focus zetec and it conked out while driving now the thing is someone has looked at it and it turns over but the cambelt doesn't turn the belt is still tight and hasen,t broken any ideas please ollie Quote Link to comment Share on other sites More sharing options...
RScab Posted July 5, 2013 Share Posted July 5, 2013 It may hav slipped Col or it has snapped but trapped makin look as if its ok Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted July 5, 2013 Author Admin Share Posted July 5, 2013 there taking it to the garage this week so will let you no Quote Link to comment Share on other sites More sharing options...
RScab Posted July 5, 2013 Share Posted July 5, 2013 may be the Crank pulley slippin - it has No keyway Ollie 1 Quote Link to comment Share on other sites More sharing options...
Guest IanA Posted August 3, 2013 Share Posted August 3, 2013 Had this happen to me on a V@uxh@ll V!v@ 1600 OHC. Teeth on the belt had stripped- crank pulley was just spinning and not turning anything else. Not an interference engine so fitted new belt, no probs. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 3, 2013 Share Posted August 3, 2013 If your tuning it over and the cam belts not moving. The pulley bolt has loosened on crank. As said before it has no key way and is just friction held. You'll now find when done up you'll probably have a lot of bent valves and maybe piston damage. I would bother taking it to garage. I'd source a new second hand engine and get them to fit it. Pointless wasting labour taking it apart. Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted August 4, 2013 Author Admin Share Posted August 4, 2013 Yep total head recon all valves and guides £1200 later They reckon bolt wasn't tightened up correctly hence damage Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 4, 2013 Share Posted August 4, 2013 Second hand engine and fitting would have come in at around £800. Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted August 4, 2013 Author Admin Share Posted August 4, 2013 Second hand engine and fitting would have come in at around £800. trouble was they brought the car from a garage and was told it had been serviced and new cambelt etc then this happened had it not been there main car they may of gone down that road lee but as you can imagine they were not very happy it had to be dealt with via the garage they got the car from Quote Link to comment Share on other sites More sharing options...
Guest taz1787 Posted August 5, 2013 Share Posted August 5, 2013 so garage would have cough up the bill surely if its their mistake Ollie Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted August 5, 2013 Author Admin Share Posted August 5, 2013 Long story taz they gave the job to someone else Now no one wants to take the blame or pay costs Not really sure of the ins n outs Turned out to be an expensive focus saloon as the clutch went a week later £450 :-( Quote Link to comment Share on other sites More sharing options...
Guest taz1787 Posted August 6, 2013 Share Posted August 6, 2013 ffs she didn't have much luck with it then but that said it does fall on the garage selling car under the sale of goods act 1979 even private sellers are now under these although a private you persue through a small claims court but a business / trader you don't it would be through standard channels i.e solicitor / courts etc more about the sale of goods act here http://www.which.co.uk/consumer-rights/regulation/sale-of-goods-act/ Quote Link to comment Share on other sites More sharing options...
Guest IanA Posted August 7, 2013 Share Posted August 7, 2013 Piston to valve contact can knacker the big ends as well- new shells needed. Quote Link to comment Share on other sites More sharing options...
