Guest zanrimanon Posted June 19, 2013 Share Posted June 19, 2013 Hi. I've just bought my Ford escort cabriolet today and there is no owners handbook. I have figured out how to manually lower the roof but can any please explain how I use the electric side to it as can't figure out. Thanks in advance Ryan Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted June 19, 2013 Admin Share Posted June 19, 2013 hi ryan not sure which model you have have you tried with ignition on first turn of the key with handbrake on and keep your finger on the butto as sometimes there a little slow to start let us no how you get on Quote Link to comment Share on other sites More sharing options...
Skittles80 Posted June 22, 2013 Share Posted June 22, 2013 Some times the tap on the pump is left open this may of been opened by the previous owner or may be low on fluid the pump is in the left hand side of the boot as a full and minimum mark if it was easyish to move roof manually chances are the tap is open some people do this as they don't know what fluid to use good luck mark Quote Link to comment Share on other sites More sharing options...
