Guest famasfilms Posted June 3, 2013 Share Posted June 3, 2013 Hi, I have seen an EFI Escort/Fiesta RS Turbo engine on Ebay. I asked the seller if it will go into my mk IV cabriolet. He said all it needs is the relevant wiring loom and ecu "and then your car will go like a rocket" Is this information correct? My understanding was an RS Turbo conversion requires other parts such as the correct radiator, as well upgrading of other parts eg gearbox, brakes, clutch etc. Quote Link to comment Share on other sites More sharing options...
Guest taz1787 Posted June 3, 2013 Share Posted June 3, 2013 first of all is your car a efi or a mfi engine then you need the correct wiring and ecu like said you will then need rst engine rad intercooler hoses exhaust possibly a petrol tank best way to do it would be to buy an escort rst donor car as everything you'll need will be there Quote Link to comment Share on other sites More sharing options...
Guest famasfilms Posted June 3, 2013 Share Posted June 3, 2013 I honestly don't know which engine type it is...it's a 1990 g reg plate. What's the easiest way to tell them apart? I'll upload a picture later Sounds like the cost is quickly going to start adding up! Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted June 4, 2013 Admin Share Posted June 4, 2013 having an rs engine fitted is never gonna be cheap lol Quote Link to comment Share on other sites More sharing options...
Guest famasfilms Posted June 4, 2013 Share Posted June 4, 2013 (edited) I took a pic of my engine, can anyone tell me what type that is and what the best option would be in terms of engine replacement/upgrades e.g RS Turbo route or Zetec route Edited June 4, 2013 by famasfilms Quote Link to comment Share on other sites More sharing options...
RScab Posted June 4, 2013 Share Posted June 4, 2013 MFi Quote Link to comment Share on other sites More sharing options...
Guest taz1787 Posted June 4, 2013 Share Posted June 4, 2013 well a zetec engine is the cheapest & easiest engine to install as you can use nearly all the parts you have but wiring them up isn't easy however if you could get a escort rst engine complete / loom & ecu's / exhaust / rad / intercooler / pipe work you can use your gearbox d/shafts petrol tank fuel pump etc so pretty easy to install and get running Quote Link to comment Share on other sites More sharing options...
Guest famasfilms Posted June 5, 2013 Share Posted June 5, 2013 well a zetec engine is the cheapest & easiest engine to install as you can use nearly all the parts you have but wiring them up isn't easy however if you could get a escort rst engine complete / loom & ecu's / exhaust / rad / intercooler / pipe work you can use your gearbox d/shafts petrol tank fuel pump etc so pretty easy to install and get running Just to make sure I understand you correctly, the options are: a) Source a breaking RS Turbo with decent engine and all the extra parts you mentioned. Source a zetec engine with no additional parts needed Seems like the Zetec route is cheaper and less hassle? Quote Link to comment Share on other sites More sharing options...
Guest famasfilms Posted June 6, 2013 Share Posted June 6, 2013 There's no way I will be able to fit this myself. Which garages/engine builders could carry this out? I have already been referred to Oddkidd Creations and Norris Motorsport, are there any others? Quote Link to comment Share on other sites More sharing options...
Guest famasfilms Posted June 6, 2013 Share Posted June 6, 2013 I'm in Southampton..so a drive to Essex is feasible....a drive further north than Birmingham probably isnt Quote Link to comment Share on other sites More sharing options...
