Mk4 Rear Bumper
Guest Matthew Davenport
I bought a replacement rear bumper for my mk4. The inside is different though. It has a sort of dense foam on the inside. The original one didn't. The original bumper just had a plastic (reinforcing) panel on the inside. The foam is quite thick so the bumper doesn't quite fit flush with the rear of the body.
Is this an aftermarket/non ford bumper, or is it from an earlier year? Mine is a 1990 spec.
The replacement bumper doesn't have any ford stamp as far as I can see
That's strange? The one that I thought was original has no foam, but it does have a ford stamp. I'll post a picture of them both later
ok, cheers Chris. I'll stick with it then. just wanted to make sure it was the right one.
as gingergman says you can a still see the foam when the bumper is fitted. just looks a bit odd as i'm used to the old one.
the old 1 is a uk spec. basic impact 1.. once it's fitted try running a blade round the over lapping foam to trim it off
ok cheers, it was the guy doing the respray who thought it may have been a non ford one.i'll tell him its ok to crack on with
  • 3 weeks later...
I always used to block any gaps and fill in the plastic ones with expanding foam as I found they sounded "cheap" and rattly, especially if you have a sound system.
