mickyfin32 Posted October 11, 2011 Share Posted October 11, 2011 bought a new roof weeks ago(mk4) installed it so far so good then snap tension cable, so after a few days of waiting for fords i threaded through new tension cable tightened it up both side pretty much all the way and looked around the back and i can still see the cable i know this isn't right. also noticed the lower bar of the rear window has rusted so bad its lost its strength and bowed leaving a gap between rubber n window so got it leaking. and its leaking from the corner of the doors did fix this problem on old roof so not too happy need advice on what do i do next?? Quote Link to comment Share on other sites More sharing options...
gingergman Posted October 11, 2011 Share Posted October 11, 2011 i used a screwdirver very carefully to prise the cable back into its correct slotting position. where is it leaking in from the doors? Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted October 11, 2011 Author Share Posted October 11, 2011 (edited) yeh seeping in from the top of the doors both sides on old roof this wasnt a problem, and from the rear window where the bottom of the bar of the window has bowed any and all suggestions Edited October 11, 2011 by mickyfin32 Quote Link to comment Share on other sites More sharing options...
Guest bobbybear1972 Posted October 12, 2011 Share Posted October 12, 2011 That bars gotta come out fella, and you either need to replace it or cut out the rotten part and sleeve with a new piece of tube,( and weld both ends) I cant see another way round it. perhaps some one may have a frame on here. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted October 12, 2011 Share Posted October 12, 2011 I have a spare frame with nackered cover on it. The frame aint rusted at all. Also have a roof with a very good vinyl cover on it. £150 for the one with decent cover. £35 for the frame. I can post but its likly to be expensive or collect for free from nn11 Quote Link to comment Share on other sites More sharing options...
gingergman Posted October 12, 2011 Share Posted October 12, 2011 im kinda lost as to what bar is being talked about? Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted October 13, 2011 Author Share Posted October 13, 2011 i got an old window and full frame thanks guys though it might had to be cut out and welded but at risk of melt the vinyl?? ginger boy the bar im on about is the attached to the frame that holds the rear window in place and which the thick black rubber sits on... Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted October 25, 2011 Share Posted October 25, 2011 The back window rubber is stapled in from new to stop the window getting blown out when travelling with window down on car... Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted October 25, 2011 Share Posted October 25, 2011 None of the ones i have ever taken apart had the window rubber stapled to the frame. The hood cover was stapled. The rear window takes some getting out. I usually have to use my feet to push it out and its still difficult Quote Link to comment Share on other sites More sharing options...
