Guest aliowen Posted July 24, 2011 Share Posted July 24, 2011 Hi wonder if any1 can help me, I've put a 1.8 zetec into my 1990 cabby, I brought a 95 escort (internal pats) donor car with key's. Done all the mechanics. Then went on too do the wiring and that's where the problems started lol. Done all the relays and everything works except there's no spark too plugs, pump kicks in and all the sensors are live including live too the ignition coil. I have a funny feeling that the pats has kicked in (everything was working when I brought the doNor car). The thing I need to know is there any way of been able too check if the pats has kicked in or if any1 can throw any ideas as too why there's no spark, I've taped the key too the transponder. If any1 could help it would be much appreciated has I am now banging my head against a brick wall " so too speak " Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted July 24, 2011 Share Posted July 24, 2011 umm not sure about zetec but have you hook up the crank sensor? everything could be working fine but if crank sensor isnt attached you wont get any spark(crank sensor is where the gear box meets engine at the front usual above starter motor ).... hope it helps Quote Link to comment Share on other sites More sharing options...
Guest aliowen Posted July 24, 2011 Share Posted July 24, 2011 umm not sure about zetec but have you hook up the crank sensor? everything could be working fine but if crank sensor isnt attached you wont get any spark(crank sensor is where the gear box meets engine at the front usual above starter motor ).... hope it helps Yes m8 checked the crank sensor and it is connected, a m8 had already point me in that direction Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted July 24, 2011 Share Posted July 24, 2011 connected ummm have you taken it out to have a look at the condition, either that try coil pack.... and thats the extent of my expertise lol good luck let us know what it is... Quote Link to comment Share on other sites More sharing options...
Guest aliowen Posted July 25, 2011 Share Posted July 25, 2011 connected ummm have you taken it out to have a look at the condition, either that try coil pack.... and thats the extent of my expertise lol good luck let us know what it is... yep taken out m8, it looks ok,like I said everything was working in donor, may just try replacing the crank sensor and see what happens. Cheers for your help anyhow Quote Link to comment Share on other sites More sharing options...
badger Posted July 25, 2011 Share Posted July 25, 2011 yep taken out m8, it looks ok,like I said everything was working in donor, may just try replacing the crank sensor and see what happens. Cheers for your help anyhow hi mate i have a feeling (not totally sure) that when pats cuts in the fuel pump etc won't work either have you checked the coil pack there are 3 connecters on there the middle one should be 12volts all the time with ign on, it then sends a signal to either side and fires 2 plugs at once. i did have it once where the plug connectors had spayed out so i lost one side of the signal and wouldn't fire... Quote Link to comment Share on other sites More sharing options...
Guest aliowen Posted July 27, 2011 Share Posted July 27, 2011 hi mate i have a feeling (not totally sure) that when pats cuts in the fuel pump etc won't work either have you checked the coil pack there are 3 connecters on there the middle one should be 12volts all the time with ign on, it then sends a signal to either side and fires 2 plugs at once. i did have it once where the plug connectors had spayed out so i lost one side of the signal and wouldn't fire... The fuel pump does kick in when you first turn the key, I can hear it, all the sensors are live even too the coil pack, I've tried looking at the connection on the coil pack and it all looks fine. I tried moving the key away from the transponder and the fuel pump still kicks in when you turn the key. It's really starting too do me head in now , I've tried everything that I know of too no avail. Does any1 now of where I can get a none pats loom and ecu from, I've tried around leeds and no luck, also tried ebay. Thanx for your help Quote Link to comment Share on other sites More sharing options...
Guest snoopaloopa Posted August 6, 2011 Share Posted August 6, 2011 Try www.rsturbos.com :-) Quote Link to comment Share on other sites More sharing options...
Guest Hearsepilot Posted November 22, 2011 Share Posted November 22, 2011 What flywheel did you use in this transplant? Quote Link to comment Share on other sites More sharing options...
