MarineIguana Posted February 8, 2011 Share Posted February 8, 2011 I have got a new relay for my rear heated screen that has never worked, The switch works, the screen has a complete circuit and the wiring is all ok, I just can't find where the relay is meant to go I have looked under the bonnet in the fuse box but that has no indication of the screen there so thought it might be behind the dash but can't see it. It probably don't help that the wiring behind the dash is a mess got relays from a VW and Toyota in there and no fuel pump relay just a piece of wire :( Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted February 8, 2011 Author Share Posted February 8, 2011 Behold my awesome wiring Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted February 8, 2011 Share Posted February 8, 2011 haha that yellow one looks simular to the one i have for my speak adjuster on my mk4 good luck sorting this one out mate!!!! not sure with mk3, mk4 all the relays you need are driverside under dash and 2 in the boot for electric roof Quote Link to comment Share on other sites More sharing options...
Guest Radman123 Posted February 8, 2011 Share Posted February 8, 2011 I have got a new relay for my rear heated screen that has never worked, The switch works, the screen has a complete circuit and the wiring is all ok, I just can't find where the relay is meant to go I have looked under the bonnet in the fuse box but that has no indication of the screen there so thought it might be behind the dash but can't see it. It probably don't help that the wiring behind the dash is a mess got relays from a VW and Toyota in there and no fuel pump relay just a piece of wire :( Hope this helps, although it is from the hatch back manual. Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted February 8, 2011 Author Share Posted February 8, 2011 Cool will have a look later, Although I think I need a new loom cos this one looks **** , Proper mess under there Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted February 9, 2011 Author Share Posted February 9, 2011 Right replaced relay, Light on switch works screen clears but the switch doesn't hold so need a new one, but at least it clears now Sod the other foreign relays they have asylum in my cab now not going to temp fate and touch them Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted February 9, 2011 Author Share Posted February 9, 2011 Hope to have another switch on its way see if it works proper then Quote Link to comment Share on other sites More sharing options...
