mickyfin32 Posted February 1, 2011 Share Posted February 1, 2011 (edited) i snapped my indicator where it met the headlight which left an annoying gap so ordered a new one which arrived so took old one out put new one in and there is still a gap any suggestions?? here's driverside gap not so bad Edited February 1, 2011 by mickyfin32 Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted February 1, 2011 Author Share Posted February 1, 2011 http://i1108.photobucket.com/albums/h416/Michael_Van_Birgelen/Image0264.jpg http://i1108.photobucket.com/albums/h416/Michael_Van_Birgelen/Image0265.jpg Quote Link to comment Share on other sites More sharing options...
Guest Tuft Posted February 1, 2011 Share Posted February 1, 2011 Looking at the photos it seems the indicators are in line with the wings, which looks right. It could be the headlight itself that is out. Maybe the beam adjuster on the nearside headlight needs a look at? Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted February 1, 2011 Author Share Posted February 1, 2011 here's the old indicator http://i1108.photobucket.com/albums/h416/Michael_Van_Birgelen/Image0180.jpg Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted February 1, 2011 Share Posted February 1, 2011 I'd try adjusting the headlight as that may help. From looking at the seam where the wing joins the front panel it looks like the car has had a wing fitted at some point. Maybe not 100% aligned. Failing the adjustment some shaping of the headlight braket and spacers on the indicator mounting may be able to give a better look? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted February 2, 2011 Share Posted February 2, 2011 I would just hit it with a big hammer pmsl.......as other's have said try adjusting the head light over. Not only that you got after market indicator's you numb nut. Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 2, 2011 Share Posted February 2, 2011 aftermarket lights allways fit poorly. i reckon you have knocked the headlight over a little bit as said. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted February 3, 2011 Share Posted February 3, 2011 Did you use the bracket's which come with indicator's? My clear indicator's came with a bracket and the bracket was crap fitting it pushed the indicator out. Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted February 3, 2011 Author Share Posted February 3, 2011 bracket was better then the old one which looked sorry for itself didnt push it out just little bits on the car that are doing my head in Quote Link to comment Share on other sites More sharing options...
