Guest errol Posted January 20, 2011 Share Posted January 20, 2011 i have a escort with a 1.4 engine and when i went to do the mot it failed due to high co the co reading was at 1.39 what could the problem be guys ? Quote Link to comment Share on other sites More sharing options...
badger Posted January 20, 2011 Share Posted January 20, 2011 i have a escort with a 1.4 engine and when i went to do the mot it failed due to high co the co reading was at 1.39 what could the problem be guys ? what year car???? Quote Link to comment Share on other sites More sharing options...
Guest errol Posted January 20, 2011 Share Posted January 20, 2011 its a 1995 1.4 cvh engine fuel injection if u want and have msn i could add u up and chat better to help me faster mate Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted January 20, 2011 Share Posted January 20, 2011 petrol treatment do an oil change change ur oil filter check your air filter and use winsoil great stuff or any other engine cleaners Quote Link to comment Share on other sites More sharing options...
Guest errol Posted January 20, 2011 Share Posted January 20, 2011 already did a full service changed oil plus filter spark plugs leads changed lambda sensor as i had idle problems and took the car to check it out and lambda was faulty got the injectors out and cleaned and than went to mot and failed Quote Link to comment Share on other sites More sharing options...
Guest RelaxedDiver Posted January 20, 2011 Share Posted January 20, 2011 Ive had this problem twice on the cabs, once on a 1.4 dash mk5 and the other on a 1.8 zetec mk6 on the dash: the car had been standing for about 3months before I took it in, it was high, so I took it for a rag round the block and it cleared it throught. on the mk6: it had been in use every day, took it for the mot and was high, tried giving it a rag round the block which didnt work. gave it a full service and changed the lamba sensor, still high (had it tested). change the cat and it was virtually down to zero. hope this helps rd Quote Link to comment Share on other sites More sharing options...
Guest errol Posted January 20, 2011 Share Posted January 20, 2011 so ur saying it was the catalytic converter mate i changed mine about 4 years ago not oem though Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted January 20, 2011 Share Posted January 20, 2011 If it's the efi you need the mixture adjusted as it is prob running to rich. I had the same issue. The mot station should of known this and a decent place would of adjusted it while on the machine. A garage will charge about £20 to do Quote Link to comment Share on other sites More sharing options...
Guest errol Posted January 20, 2011 Share Posted January 20, 2011 i dont think mine is adjustable Quote Link to comment Share on other sites More sharing options...
badger Posted January 21, 2011 Share Posted January 21, 2011 i dont think mine is adjustable it does sound like the cat and if you changed it 4 years ago and put a pattern part on its about the right time to change it again if your lamba is good it can only be the cat at fault Quote Link to comment Share on other sites More sharing options...
Guest errol Posted January 21, 2011 Share Posted January 21, 2011 i am going to change the coolant temperature sensor next week propably as it has something to do with co too Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted January 21, 2011 Share Posted January 21, 2011 Should be, there should be a a little black thing screwed the inner wing right infront of the battery Quote Link to comment Share on other sites More sharing options...
Guest errol Posted January 21, 2011 Share Posted January 21, 2011 mine is under the injectors in the back of the engine Quote Link to comment Share on other sites More sharing options...
Guest errol Posted February 10, 2011 Share Posted February 10, 2011 ok guys got the car fixed it was the cat after all now i have another small problem its the fuel gauge its not working properly I mean I know that when u accelerate the fuel gauge goes down and when u slow it goes back up but it is sometimes sticking to the same point what could that be Quote Link to comment Share on other sites More sharing options...
Guest errol Posted February 10, 2011 Share Posted February 10, 2011 so basically sometimes it works and sometimes it doesnt Quote Link to comment Share on other sites More sharing options...
Guest RelaxedDiver Posted February 10, 2011 Share Posted February 10, 2011 glad u got the car through Quote Link to comment Share on other sites More sharing options...
Guest errol Posted February 10, 2011 Share Posted February 10, 2011 any info on the fuel gauge problem anyone? Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted February 10, 2011 Share Posted February 10, 2011 Shouldn't be going up and down as you accelerate. The mk4 has this problem when people change the tank sender or fuel guage in the dash as there are two types that must be matched. I don't know if there are different types between mk5/6 models. Maybe there is and one or the other has been replaced. Failing this i would probably change the fuel guage in dash as its easier to do than the tank sender. Quote Link to comment Share on other sites More sharing options...
Guest errol Posted February 11, 2011 Share Posted February 11, 2011 everything in this car is original nothing has been replaced Quote Link to comment Share on other sites More sharing options...
Guest errol Posted February 11, 2011 Share Posted February 11, 2011 any help guys Quote Link to comment Share on other sites More sharing options...
