Guest f60ant Posted January 15, 2011 Share Posted January 15, 2011 hi im new to escort convertibles but after driving my car it is apparent that it suffers from bad scuttle shake. i have stripped the seats and carpet out to check for rust and had a look under at the floor and sills and all is mint no probs at all. while i had it on the four axle stands i could grab the back bumper and lift it and the whole car would twist, i would say with the roof up it was 70% better. so my question is, is there any way of fixing this problem ie welding some gussets in somewhere? cheers ant Link to comment Share on other sites More sharing options...
chaz Posted January 17, 2011 Share Posted January 17, 2011 Escort cabs suffered frome some scuttle shake from new, but I am not sure if what you mention is normal, mine is hardly noticable. Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted January 18, 2011 Share Posted January 18, 2011 They do flex, even more so with the roof down but never heard or seen it that bad. Are you sure the sill are ok and not just bodged up to look good. Link to comment Share on other sites More sharing options...
Guest Charlie 5 Posted January 20, 2011 Share Posted January 20, 2011 That sounds disturbing!! Link to comment Share on other sites More sharing options...
gingergman Posted January 25, 2011 Share Posted January 25, 2011 does not sound normal to me, cut and shut Link to comment Share on other sites More sharing options...
