Best Place To Buy A Fuel Pump?
gingergman
Guest s6boy1979
Hi Stu
Depends what you want from it. If your not going for big power then ebay is cool, but if your going to up the power at some stage or swap it for something a bit quicker then burton power is prob the best place for an uprated one, look for a fez turbo/cozzy onr. Or you can do what i am doing and swap the efi set to mfi. This way the pump is external and is to get to so you can change it to suit your needs, plus they are a bit cheaper for some reson.
it will be running standard for prob around another year, so ebay is the best then? mine hasnt gave up yet but its off at the mo so might aswell put a new one on it lol.
can you run a uprated one with a standard engine, or will that cause some probs?
Item number: 370387431521
this is the guy i got mine from check the part numbers etc they have loads for sale at different prices from £39 to £45.
hope this helps mate
As far as i know the fuel pump on the bosch ke jet rs turbo is the same as the one for the standard xr3i. Sytec sell pumps direct which are reasonable priced. Go for the equivilent of a bosch 044 if memory serves me is standard. Think about replacing wiring to it also. Virtualy all the cars that havent had it replaced have a voltage at the pump when working lower than it should be
Guest s6boy1979
That's a pump for an mfi external pump. Stu needs the one that goes in the tank which is a lot smaller and a strainer bit on bottom
tis cool mate! id be alright if it was efi cos ive got a pump thats only been used for two weeks so is like new, but cant shift it lol.
gonna speak to my spares place see what he says about a pump, need some other things so might aswell ask when im there!
  • 2 months later...
Just one comment, a pattern pump only lasted four years on my cab, although
my Mechanic friend blamed lack of use,Since a few months ago I have an original
Bosch and it is a lot quieter too.
Edited by chaz
