Leaking Seals
JacquiB
Hi Guys
Any1 have any idea how to stop my cab from leaking in when it rains??
Comes in where roof joins to window, all through the seals!!
Sick of getting wet floor, setats and bum!!
Any suggestions would be much appreciated!!
Thanks
Jacqui
x x x
  • 2 weeks later...
what window is the water coming in from? side or where the roof meets the front screen?
hi gnigerman (again) lol
it comes in on both drivers side and passenger side.
both where the roof meets the window
any ideas??
it must be coming in somewhere else too cuz
passenger side floor and rear floor gets really wet, i mean
like u might need arm bands to get in lol
xxx
  • 2 months later...
hi
im thinkin my seals need changing but
cant seem to get any from anywhere
any ideas??
thnx
jacqui
x
hi jacqui if its anything like mine it was a pain in the bum especially as i had to keep taking the interior out to dry it all out to save the floor starting to rot. so here is what i done to save buying new seals 1. i took the door panels off and adjusted the bolts that hold the motor to door and the channels aswell and it made it a little better but wanted to go further so took all the bolts out and made the holes a bit larger to make the window go up further and that worked well but the only thing i forgot to do was put new washers on so they would grip the panel and stop them from sliding on the longer holes so after a while they moved a little alowwing a little gap.
2. i changed the seal that goes round the windscreen for a better one with a rain channel in and worked great. but still have a slight gap.
3. after a long while of spending time on it i then had a thought. if i open the door and help the glass up whilst pressing the window button the glass comes further up and creates a perfect seal even in the heaviest of thunder storms.
so now i have a constant dry car what ever the weather. the reason the glass wont seal against the roof seals is a possibly a combination of badly adjusted roof and worn rubbers.
if you want more info just give me a shout. or if you are up north il sort it out for you.
ok thnx very much for that will try out wot uve said!! if no luck will be bk in touch
thnx for the offer too but im not up north, in the west midlands but thnx anyway
jacqui
xxx
  • 1 month later...
Hi,
you first need 2 confirm where the water is gettin in
remove the carpets & sound proofing then dry out the car
its much easier to spot the leaks with carpet & sound proofing removed
then use a hose on the car (with the roof up) :biggrin:
you need 2 rule out the battery tray & the fuse box
if the water runs in from the doors/sills it may be the internal door seals
if its the roof you should be able 2 spot the water runin down the doors or entering from the rear quarters etc.
hi
thnx very much
could do with some help
but easier said than done at the min
recently started a new job so need the
car ALL the time!! But i have to take
residents out in the car so need to get it
sorted ASAP!! Catch 22 really!! lol
oh well
thnx anyways
jacqui
xxx
