gingergman Posted July 15, 2010 Share Posted July 15, 2010 my passinger window doesnt work! fort it was the motor, tried two others, no joy, tried a diffrent switch, no joy, any suggestions or ideas? as i need it working asap to put the rest of the door together! Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted July 15, 2010 Share Posted July 15, 2010 you checked the feed to motor with test light or multi meter Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 15, 2010 Author Share Posted July 15, 2010 no not yet, but ive tried a few motors so it cant be getting power to it, by any chance, does the wiring from the passinger side mix in to the wiring from the drivers side somewhere along the line? because when i cahanged the drivers door was when it stopped lol Quote Link to comment Share on other sites More sharing options...
Guest spenny Posted July 16, 2010 Share Posted July 16, 2010 no not yet, but ive tried a few motors so it cant be getting power to it, by any chance, does the wiring from the passinger side mix in to the wiring from the drivers side somewhere along the line? because when i cahanged the drivers door was when it stopped lol yes mate the wires do mix behind the dash .sounds like you could have a brake in the wire. your gonna have to take the dash out and find the wires and check them all for continuity . common brake point in the wire is were it enters the door. good luck Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted July 16, 2010 Share Posted July 16, 2010 Check your earths as well, could just be that. Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 16, 2010 Author Share Posted July 16, 2010 i hate electrical problems! oh the joy im gunna have with this, thanks for the replies,i shall keep my progress or lack of it updated lol Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted July 16, 2010 Share Posted July 16, 2010 did you plug both wires back together? check the wires on driver's door switch... if not common for break in rubber protecting wires on passenger door.... Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 16, 2010 Author Share Posted July 16, 2010 ive got this spare connector in the door? but i dont remember ever dis-connecting it Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted July 16, 2010 Share Posted July 16, 2010 did you strip the new door or just fit it ? you should have 3 plug ...1 for window's......1 for c/locking.....1 for elec/mirror's depends what you have on your car tho this is how i remember mine being not been in the door for a bit tho hope this help's Stu cab looking Quote Link to comment Share on other sites More sharing options...
Guest spenny Posted July 16, 2010 Share Posted July 16, 2010 thats for the mirror's .. my cabby had the wires in for them but never had the mirror's to go with it. i just stripped them all out so not to confuse me Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 16, 2010 Author Share Posted July 16, 2010 for the mirrors ay! cheers buddy i fitted the door complete, but the body shop have since taken both off and put them back on, think i will have a root around the drivers side first, any ideas where the grounding points would be? think one behind the speaker and behind the dials mabye? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted July 17, 2010 Share Posted July 17, 2010 SURE THEY WERE BEHIND DRIVERSIDE SPEAKER IN KICK PANEL... LET US KNOW IF YOU DO IT Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 17, 2010 Author Share Posted July 17, 2010 had a good day on the car today, attempted the window last, had my mate with me who understands electrics alot better than me lol. have found out it is a bad earth, all the wires on the passinger loom are live, so ive gotta find the earth, there is alot down in the drivers side footwell behind the speaker i know, but is there anymore anywhere? and if it is the earth behind the speaker how come everything else still works lol Quote Link to comment Share on other sites More sharing options...
allblue Posted July 17, 2010 Share Posted July 17, 2010 If you are getting live to the passengers side, have you tried examining the connectors that connect to the motor? Sometimes corrosion builds up in them or they break internally. Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 17, 2010 Author Share Posted July 17, 2010 yeah i checked all the connectors for power feed, all are fine, one was a bit corroded so i sorted it, im hoping to get it working tommorrow lol, Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 18, 2010 Author Share Posted July 18, 2010 still doesnt want to work the earths seem fine, i tried earthing it from all connections and even the switch, no joy, any ideas? relay? or would that make both windows not work? Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted July 18, 2010 Share Posted July 18, 2010 Stu, if you dont have it working by the time ford fair comes around, i will have a look at it for you, in the mean time have you checked that the motor goes up and down ok ? if not, run 2 wires direct from the battery with a 10A fuse in the +12v wire, and connect directly to the window motor, if nothing happens reverse the wires on the motor and try again, i did say in an earlier post it could be an earth prob, and i still think that is where your prob is, hope this helps. Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 18, 2010 Author Share Posted July 18, 2010 the motor is ok, tried 3 others, they didnt work when connected but did when connected to the drivers side loom, i do think its a earh but im too confused by it now lol, the window is up so think im just gunna leave it stuck up for the time being lol, And cheers tony, if you can spare a few mins at ford fair that would be great and would be very appreciated Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted July 19, 2010 Share Posted July 19, 2010 No prob Stu, i look forward to it m8. Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 19, 2010 Author Share Posted July 19, 2010 Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted July 20, 2010 Share Posted July 20, 2010 (edited) Know it sounds silly but have you checked the connection in passenger kick panel still connected? is there a live and earth coming to here? did you check the wiring loom in the door shut? as they break in the rubber and maybe shorting out that's were mine broke before and my m8's done the same Edited July 20, 2010 by shaun Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 20, 2010 Author Share Posted July 20, 2010 everything in the door gets power so the wires in so the wires in the door shut should be fine, there was no earth anywhere tho, think the haynes says it should be in drivers footwell but all seemed fine? Quote Link to comment Share on other sites More sharing options...
Guest dodgy01 Posted July 21, 2010 Share Posted July 21, 2010 everything in the door gets power so the wires in so the wires in the door shut should be fine, there was no earth anywhere tho, think the haynes says it should be in drivers footwell but all seemed fine? how many wires does the motor have going to it if it has only 2 then there will be no earth untill the switch is depresses as it flips the pos and the neg from side to side sorry if i am steering you wrong but thats how the later ones work Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 21, 2010 Author Share Posted July 21, 2010 it has two wires going to it, there is a earth off the drivers switch Quote Link to comment Share on other sites More sharing options...
Guest dodgy01 Posted July 21, 2010 Share Posted July 21, 2010 it has two wires going to it, there is a earth off the drivers switch so i i get this right this is what you should get when the switch is pressed up you get a live at 1 of the pins and when it is pressed down the live goes to the other pin and the same with the negative so for example window up = pin 1 live pin 2 neg window down pin 1 neg pin2 live this is what should happen Quote Link to comment Share on other sites More sharing options...
