Guest Cabbytech Posted July 22, 2010 Share Posted July 22, 2010 I agree, thats exactly what should happen, and the wiring from the passenger door should all wire through to the drivers door where the drivers and passenger side other switch is, have you tried replacing the passenger switch in the drivers door Stu, just in case this one is faulty ? Quote Link to comment Share on other sites More sharing options...
Guest dodgy01 Posted July 22, 2010 Share Posted July 22, 2010 I agree, thats exactly what should happen, and the wiring from the passenger door should all wire through to the drivers door where the drivers and passenger side other switch is, have you tried replacing the passenger switch in the drivers door Stu, just in case this one is faulty ? so do you get this from the back of the switch posotive and negative switching Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 22, 2010 Author Share Posted July 22, 2010 ive tried the drivers switch on the passinger door, but not passinger on drivers side lol, would that make a diffrence? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted July 24, 2010 Share Posted July 24, 2010 sure you need to use the right switches for the windows.....not sure tho??? Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 25, 2010 Author Share Posted July 25, 2010 na, when a switch stopped wrking on it before i swaped them over and was fine Quote Link to comment Share on other sites More sharing options...
Guest dodgy01 Posted July 26, 2010 Share Posted July 26, 2010 (edited) so do you get this from the back of the switch posotive and negative switching did you get time to check this how many wires come from the back of the window switch in total Edited July 26, 2010 by dodgy01 Quote Link to comment Share on other sites More sharing options...
