Guest wilkiebabe Posted April 4, 2010 Share Posted April 4, 2010 Hi i wondered if anyone can help change the cog on the electric it now works but now when it goes up there is a short fall whereby the roof doesnt close proper properly about half an inch and i reallly need to pull it to close it and then the roof is still not closed properly as u can hear it when drive the car any ideas as to y and what i need to do Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 4, 2010 Share Posted April 4, 2010 hi, what mk cab is it? did it use to close alright or has it always been like it? Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted April 4, 2010 Share Posted April 4, 2010 if there is a slight gap is it something that could be sorted by adjusting the roof handles Quote Link to comment Share on other sites More sharing options...
allblue Posted April 6, 2010 Share Posted April 6, 2010 When the cog was changed, was the system bled with oil properly? Could be a bit of air in the system perhaps? Quote Link to comment Share on other sites More sharing options...
Guest wilkiebabe Posted April 14, 2010 Share Posted April 14, 2010 Hi Escort is a P reg, we had car for a year or so and roof wasnt working when we brought it so we just kept pushing it up and down. Brought the cog kit and just before we fitted it started having problems with the roof not shutting fully getting stuck half way and having to really pull it to get it closed. then changed cogs but roof would still not close properly. If need to bled system how do we do it Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 17, 2011 Share Posted May 17, 2011 If the roof wont close manually all the way with the valve open on the pump then there is only a few possible causes. There could be a fault of some sort in the rams. i.e detachached piston end or seized. The roof frame is broken or something is obstructing it. Most likly cause. I would disconnect the rams from the hood and test operation by hand. Following that lower all windows to rule out that as the cause. They have adjustable limits. Next is to remove sections of the inner hood to inspect mechanism and frame for obstructions or damage. Quote Link to comment Share on other sites More sharing options...
Guest chris123 Posted September 26, 2011 Share Posted September 26, 2011 can some please help ive just bought a mark 5 escort cab .and when i got it the roof would not close .short by about 2 inch.the skin a had its day and i little bit rusty at the front.so ibought 1 off ebay mint con.change the roofs and this 1 all so wont reach all the way .short about half a inch. it is electric but this does not work. does it need the pump working to push some more. or should it reach any way.the roof is nicely stretched with no sags can you help .and 1 more prob the roof motor is just clicking is it broke and can it be fixed.this car has been in the garage for seven years please please help Quote Link to comment Share on other sites More sharing options...
welshlad Posted February 22, 2012 Share Posted February 22, 2012 just undo the valve on the pump and try and close it manually or adjust the hooks that is unless you have already sorted it out Quote Link to comment Share on other sites More sharing options...
