Mk6 Cab
Guest danj8608
Guest danj8608
Hi this is my cabby i bought for £280 last week end
That was a pic from the previous owner
I took this pic when i went to pick it up and my god it was a load of hassle to tow, basically i attach a A frame to the lower arms and this enables it to be towed and steered. Long story short, bottom arms where nakered and a drive shaft cv has split so it wouldnt steer so i had to then get a dolly and have it towed back that way.
A few things with this car,
it is down on the log book as a si but has ghia badges and a wood dash trim fitted which can easily be fitted
also its on a p reg but heres a few things i noticed on it
suspension mounts all round are a 2 bolt set up ala mk5
the headlight brackets closest to the grille have been welded on not spot welded as they should be
also missing the brackets for the grille also.
So theres a few things that iv seen so far its solid underneath which for a escort is good and so is the rear arches, it needs for sure
1. new drive shaft and cv on passenger side
2. new hub/ stud for drivers side
3. new radiator
4. cat back exhaust ( which i have )
Iv got some mk6 gmax rear shocks,
60 mm springs
rs2k disc beam
rs2k front set up
magnex cat back
various alloys
wrc bumper
so iv got a few things to sort but so far im pretty happy got loads to do but its all fun, this will be a long project so updates may not be so often.
Thanks for looking Dan
Guest specialtaximan
BELTA MK6 FOR THE CASH M8 THOUGTH MINE WAS A BARGIN AT £500 LOL BUT THATS A SALE OF THE CENTURY HAHAHAH REALY NICE TO SEE MK6 PROJECT FOR A CHANGE LOL
KEEP UP THE GOOD WORK M8 :salut_gb:
  • 2 weeks later...
Guest danj8608
Small update, i decided to break the cabby because i saw a cossie rep shell on ebay, so i got it then it turns out it was a bit of a dog so i cut all the panels off. so i shall fit all of it
all needs work so it should be fun
Edited by danj8608
Guest danj8608
Not done much today other than look at the engine and try and start it, seems the HG has gone so its a good excuse to swap the engine.
I cant realy spend to much on the cab for the min gotta sort my van out and pay a few things then i can start.
Guest s11pyk
please please please put mk5 front on if you plan on doing a cossie rep! mk6 cossie just does not work, thats my opinion anyway! nice project tho mate
Guest s11pyk
i happen to have mk6 morrettes and a wrc bumper so thats what ill be fitting
i suppose il let you off for that then, will be a wrc cabby then! promise me no vents in the bonnet tho!
