Guest s6boy1979 Posted January 30, 2010 Share Posted January 30, 2010 Hey i have a mk4 efi and my clocks worked fine apart from the temp gauge which sat above the red all the time. I got a new set of clocks with white dials but now have a few problems. The rev counter wont go above 2000 revs no matter what, the fuel gauge now sits above the full tank mark when i know there is on half a tank left and now the temp gauge now sits half way! Confussed Any help would be great Ta Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted January 31, 2010 Share Posted January 31, 2010 was the new cloks working ok before hand? Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted January 31, 2010 Share Posted January 31, 2010 i have a simular problem well sort of my temp and fuel gauge fine my revs well i could rev the tits off her wont go above 3000 rpm on clocks as for your temp gauge check your sensor if its on red on one clocks im imagine on the other clocks the fuel n temp gauge are switched left to right so im guessing its reading temp instead of petrol !!! i got efi aswell convert from mfi been a pain in the ass.... apparently on rsbible.com/co.uk u can run a wire for your e-dis unti pin 11 to the back of your clocks and should fix the rev counter problem hope this helps you !! Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted February 1, 2010 Share Posted February 1, 2010 The clocks came from an efi and mine is a efi. All i can think is a was sold doggy clock so will need to get some more i think Quote Link to comment Share on other sites More sharing options...
