mickyfin32 Posted January 30, 2010 Share Posted January 30, 2010 hi when i changed my mk4 engine from mfi to efi i used the same gearbox but during this i did lose abit of fluid and sounds like its in need of a top up how do you do this ??? a picture would be great with a small diagram due to me being a novice!!! Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 30, 2010 Share Posted January 30, 2010 on the front of the box facing the front of the car there is a allen key bolt to undo, best to look from under the car as its hard to spot, but once you see it you can top up from looking down on it, hope that helps mate. Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted January 30, 2010 Share Posted January 30, 2010 its an 8mm allen key aswell to save you hunting for corect size Quote Link to comment Share on other sites More sharing options...
Guest steelcabby Posted January 30, 2010 Share Posted January 30, 2010 also, make sure the car is on a flat. and that you fill it so it just trickles out from the hole. Quote Link to comment Share on other sites More sharing options...
