mickyfin32 Posted January 30, 2010 Share Posted January 30, 2010 right i bought a brand new alternator and a new battery £48 problem is i was running engine this morning turned it off try to turn it back on and the battery was flat and couldnt turn the engine over,i did notice that on the clocks the battery light stayed on while the engine was running any suggestions??? Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 30, 2010 Share Posted January 30, 2010 get it running again and test the battery while running with a multi-meter to see if its getting charge from the alternator, did it not want to turn over at all? or was it just slow? Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted January 30, 2010 Author Share Posted January 30, 2010 just wasnt enough power to turn it over starter motor was so slow.. not happy the battery and alternator are both brand new... Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 30, 2010 Share Posted January 30, 2010 if the starter was slow its prob just because its got too hot while the car was running, let it cool and try again, if its fine after then get a heat shield for it Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted January 30, 2010 Author Share Posted January 30, 2010 heat shield for starter ??? well i'll give it another try and hope for the best... but why does the battery light on the clocks constantly stay on?? Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted January 30, 2010 Share Posted January 30, 2010 are they both like brand spankers new as a good battery should run a car for long time before it goes horibly flat so sujestes you have either low or no charge going on so would be looking at checking loom for faults. Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted January 30, 2010 Author Share Posted January 30, 2010 (edited) both spanking new!! what would i be looking for?? the only thing at the moment wrong with the car is the back lights blink when the indicators come on i think its a bad earth... so besides the battery light on the clocks staying on ummm....hope the starter is too hot otherwise im stumped.... Edited January 30, 2010 by mickyfin32 Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted January 30, 2010 Share Posted January 30, 2010 did you fit it yourself? if it was fitted take it back to whoever fitted them. you should check all the wires most of all your earth wires. Quote Link to comment Share on other sites More sharing options...
mickyfin32 Posted January 30, 2010 Author Share Posted January 30, 2010 did you fit it yourself? if it was fitted take it back to whoever fitted them. you should check all the wires most of all your earth wires. yes i installed myself... all connections are good the wire from alternator to starter motor is intact and damage free..... ummm.. but still wondering why the battery light on the clocks remained illuminated while the engine was running funny enough the handbrake light stayed on aswell and i just replaced the switch.... Quote Link to comment Share on other sites More sharing options...
