Guest s11pyk Posted January 3, 2010 Share Posted January 3, 2010 going back 10 years here, but when we passed our tests my mate was lucky enough to get a mk4 cab for his first car. it was a well modded D reg, looked cool in its day with rst kit, tiger stripes etc. anyway, it had 2 12" subs on the parcel shelf. sounded awesome when the roof was up, not so good when down but still ok. now iv got one and looking at the shelf, its metal? is it safe to cut large holes in this or were we cruising around in a death trap? i want some bass in my cab but dont know how to go about it. right now only the crackle masters on the passenger side work so i think it needs a new system wiring in! Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 13, 2010 Share Posted January 13, 2010 i defo would not cut the shelf, theres a lot of strenth in it and as you said, it would only sound good with the roof up, just put a couple of 12s in the boot, i use to and it was plenty of bass without buggering the car Quote Link to comment Share on other sites More sharing options...
Guest DEG Posted January 13, 2010 Share Posted January 13, 2010 got all four speakers working, drivers side weren't wired? need to update all the speakers tho. early 90's pioneers have about had it! would you ever get dacent bass with the roof down regardless of where the subs were? Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 13, 2010 Share Posted January 13, 2010 it will never be the same as a hard top car for bass but if you get some decent watt ones in the boot its still very good with the roof down. Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted January 14, 2010 Share Posted January 14, 2010 Would you cut holes in the door cards to reposition the speakers to get a better sound? Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted January 14, 2010 Share Posted January 14, 2010 Would you cut holes in the door cards to reposition the speakers to get a better sound? someones already cut bigger holes on the side of the footwells so il be getting bigger ones in there! probably would sound better in a different place Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted January 14, 2010 Share Posted January 14, 2010 When I had my last cab I remember that is one of the things I hated, when the roof was down I could hardly hear anything Quote Link to comment Share on other sites More sharing options...
Guest CABNAP Posted April 23, 2011 Share Posted April 23, 2011 try this...... get the subs upside down on back shelf ... mark them with pen .... get good size drill bit ... put holes in side the marks you did ... get spacer for subs (use wood make some) and fit subs under .... then with roof up or down...you will get good sound........ Quote Link to comment Share on other sites More sharing options...
Guest wodge Posted April 26, 2011 Share Posted April 26, 2011 just buy one of those under seat subs and for the record mine sounds pretty damn good regardless of the roofs position Quote Link to comment Share on other sites More sharing options...
Guest eddyjp Posted April 11, 2012 Share Posted April 11, 2012 i have a cerwin vega 12 inch sub and a fusion powerplant amp with very good wires and it sounds good roof up or down jus need to update the pre-war speakers now Quote Link to comment Share on other sites More sharing options...
Guest snoopaloopa Posted April 19, 2012 Share Posted April 19, 2012 (edited) Infinity sub/Rockford Fosgate amp in the boot in mine with alpine components in standard positions, running off a Pioneer headunit and I can hear it roof up or down no problem Edited April 19, 2012 by snoopaloopa Quote Link to comment Share on other sites More sharing options...
