Heating Wont Work
Guest ajaydohc
Guest suffolk04
sounds more like a relay/motor problem than a heater matrix problem, someone on here with a mk5 may know, i have a mk4 so think it will be abit different
  • 2 months later...
Guest ajaydohc
the blower is working i stuck a wire to it to test it but wen u turn the heatting on its like its off notting at all but wen ur driving the hot air blows tru the vents
im abit lost with this now lol, so, when on idle with the heater on it blows cold and when your driving with the heater on it blows hot, or it jus trickles through the vents hot with the heater turned off while driving?
whats the engine doing temp wise?
so basicly the heator motor works just no ot air yeah?
ginger ppl get confused more easy lol
Guest suffolk04
mine used to do that, be sitting at traffic lights, and heater starts blowning cold, drive and it blows warm, mine was a blocked heater matrix.
just disconnect both pipes to matrix from bulkhead, and use a hosepipe and watch the crap come out
my old mk4 did too lol
Guest mossop1
Hehehe this is very confusing thread if ive read this right you get heat when on the move but the blower only works when you direct feed it with a wire if that is the case i would sujest that the resister that controls the fan speeds is duff hence no blow when you try to switch the fan on i aint got a clue were it is on mk5 if its the same as mk3/4 its on motor.hope i sused it out.
spot on buddy thats wat im tryna say haha its like a fuse is gone or something
Had a very simlar problem with my heater as you could feel the hot air with the vents open when driving but no blower working, also the rear heated screen did not work and I found out what the problem was, The Fuse/relay box .. it seams on some of the mk5 models had problems with dry solder joints .. I replaced it with an exact replacement one (same serial number) and hey presto it all works now, yours may have the same problem as i done the same as you and checked the heater blower ect with no joy!
Edited by animal
  • 2 weeks later...
Guest ajaydohc
the heating magicly worked today turned the key and it came on haha didnt even do anything
Guest BrillPhady
I have this same problem on my mk3 no blower but can feel the heat from the engine out of the vents when the car is moving. Also my stereo doesn't switch on ...
Guest shaun
have you tried the fuses?your motor my naff as for radio does the interior light come on?if no check fuse...check wires on the back off radio some had in line fuse....the red wire if after market radio should goto yellow and yellow wire to red...
Guest shaun
you may fine there's a risistor on your's check manual..other than that as animal said fuse box was really common on mk5 AJ...used to get loads re-paired by mobile sparks
