The Restoration\resurrection Of My Mk 4 Cabby
Guest dee1orean
Guest dee1orean
That Lexus colour would be great mate !!! :wink:
That's what I'm thinking mate, it's the closest to the Kandy without being a Kandy if you know what I mean. I'll have to see if I can find a paint code.
Remember I posted this pic of where my workmate crashed my car?
Well, after a few hours with the pin puller, a planinshing hammer and a little bit of filler, this is the result:
Looks much better doesn't it?
  • Replies 110
  • Created
  • Last Reply
Top Posters In This Topic
Guest dee1orean
Yep it's that time again, update time.
Thought it was time to make a start on flushing the fuel cap and relocating the hose.
So, the areas that neen work:
The initial cuts, I like using the cutting tool :biggrin:
Pulling the filler hose through:
The hole that needed filling, Baremetaled the rusty bits and applied plenty of kurust.
Guest dee1orean
The patch panel made up:
Offered up:
And welded in, as you can see I did start to grind the welds down and then I thought, "Hang on, they're guna want to see the knobbly bits of weld", So, here's the knobbly bits of weld! for some reason you get more "burn" when using weld through primer:
Welds ground down, I went back in and welded up the small holes you can see but didn't take pics:
And lastly using my trusty mix of 50% Polyester filler & 50% Fibreglass filler, the first application of filler:
I did start to block this out and will finish tomorrow, hopefully.
So, after the body side of things is dealt with I'm going to have to tackle the actual filler neck, I'm not worried about forming an inner arch, but am trying to figure out what to do with the filler neck.
Should I replace the whole filler pipe? if so, does anyone know the diameter of the fuel filler pipe at the tank end?
Should I do away with or try to include the breather pipe?
Should I cut the top off the original pipe and extend it somehow?
Any suggestions greatfully recieved.
Cheers!!
Edited by dee1orean
Guest murcus
i would only replace this if you cant get the angle etc you are needing, or if it looks worn
Should I do away with or try to include the breather pipe? i wouldnt, breather pipes are normally there for a reason,
when you pierce a drum and the liquid flows, it flows faster when there is a breather pipe at the top
Should I cut the top off the original pipe and extend it somehow?, as long as you use and pipes or tubes that does melt wehn petrol is poured through, but if it were me, i would just order som petrol pipe from ebay and cut it to length
but it coming along well
keep it up lol
Guest clacky
Hi, continued congratulations on the good work
Don't want to cast any gloom but will it pass the MOT with the fuel filler on the inside of the car, just thinking about the potential for petrol fumes inside the car etc etc??
Would like to know as i think it is a great improvement and would love to do the same to mine
Keep it up
Cheers
Chris
Guest dee1orean
A valid point mate.
The plan is to have the fuel neck behind the rear light, and once it's all connected up to box off the area where the pipework is.
That way there should be no risk of fumes entering the car, the fuel neck will be accessed via a hinged rear light.
Hope that makes sense.
Jez.
Guest murcus
i dont think it would make any probs passing an mot, as you can have your fuel tank in the back, as long as its in the proper container etc
i like the sound of the hinged light,
i vaguely remember a nova in max power a few years ago, that had something simmilar, and also remember one which had polly rear windows, and the filler in the middle of the window
think i still have that mag lying around
Guest dee1orean
Cheers Guys,
My inspiration for the rear light\hidden fuel filler neck came from a 55 Chevy Modification:
Rear quarter filler work all complete and sprayed with a light dust of primer, not too much as I keep the car inside anyway.
For some reason some pics of my woofer got mixed into my car pics, so let me introduce LULU
Guest dee1orean
I also had a go at revamping the recaro subframes:
As you can see they were in pretty bad shape:
Sanded down and drenched in KUrust:
And finally, painted with hammerite, along with a few other rusty bits n' bobs, not the best job, but much better than before:
Guest dee1orean
Cheers Mate, glad you like!!! :biggrin:
I try to break up the work I'm doing, just to keep my enthusiasm going, If I was doing day in day out bodywork, I'd probably burn out and lose interest, but by doing small jobs like the subframes and the seatbacks it breaks the monotony and keeps me interested.
Cheers!!
Guest dee1orean
Murcus,
Do you have any links to any fuel pipes? I can only find ones of about 6mm!
I may buy another hose designed for another car and join the two together yet.
Cheers.
Jez.
Guest clacky
Cheers!!
Hi Jez
Nice work so far !!
Hi Lulu
Saw something similar on one of the american hot rod programmes re the fuel filler pipe, always thought it made sense when i have seen it as a stock item on the yankee cars when they have it behind the hinged number plate.
Look forward to seeing the final result on this part of your project
What would we do without Kurust and Hammerite, love em :smile:
Fully understand what you say about losing interest as mine seems to have many jobs on the go all at once and i just get up and start on the one that i fancy the most on that day
Cheers
Chris
Edited by clacky
Guest clacky
Hi
i note from an earlier post that your preference was for Upol over P38.
Can i ask why you prefer Upol?
I checked on the web and notice that P38 is a Upol product as well so just wondering what the difference is as i need to restock
Cheers
Chris
Guest dee1orean
My initial Post was meant to reference "Davids P38" as in the past it's had quite a bad rep, and was the only option from halfords for the diy'er but most pro's wouldn't touch the stuff.
It's not the case so much now as halfords stock other products Such as Upol, I didn't realise that Upol fine polyester filler was also classified as "P38" which may be where the confusion lies, where did you find this info?
Guest clacky
I just happening to note on the Davids tin of P38 that i was using, that the web address was www.u-pol.com so i went and had a look and noticed that Davids Isopon P38 and Upol are both made by Upol along with P40 etc
I expect that P38 is for the domestic market, hence the small tins available and that Upol is more for the commercial end of the market.
I was just wondering what the difference is with the finish and usability between the products
Guest dee1orean
Just checked out Upols site it looks to me as if Upol have bought Davids out and are marketing it under Isopon as they list Isopon P38 & Isopon P40, whereas it used to be Davids P38 & P40, Maybe the quality has improved.
I've heard that in the past there where adhesion issues due to the filler actually hardening too much and coming away from the surface. I remember working on this old 69 Mustang and the filler was like concrete, we were chipping it away in chunks that were 1cm or more thick we assumed then that it had been Davids.
It's up to you mate but I must say I do like the Upol easylite easy sand filler paste as it's quite gloopy and easy too spread and what would I do without topstop... ahh it's heaven lol!!
Guest murcus
i preffer th use the upol easy sand as well, also doesnt set as quick as davids p38
ill have a look later mate for fuel pipes,
you should get them in a few sizes 6-8ml, then some thicker stuff with reducers to fit from filler neck,
but most cars have plastic filler necks, would be alot better with some thick rubber, or possibly have some stainless piping with a reducer to the tank?
Guest murcus
some parts and links you might find usefull:
http://cgi.ebay.co.uk/GOODYEAR-13mm-1-2-fu...alenotsupported
some 16mm hose above
http://cgi.ebay.co.uk/Ford-Anglia-105E-Pet...alenotsupported
ford anglia neck filler
http://cgi.ebay.co.uk/Rubber-petrol-filler...alenotsupported
lotus élan curved one
http://cgi.ebay.co.uk/Petrol-filler-from-a...alenotsupported
this one below i think could be usefull
http://cgi.ebay.co.uk/V-W-GOLF-MK1-1981-19...alenotsupported
the one above could be modified to fit
http://cgi.ebay.co.uk/Husqvarna-petrol-fil...alenotsupported
Edited by murcus
Guest dee1orean
Cheers for the links mate, I liked the elan spider neck, mainly for the fuel cap lol,
I've got my eye on a susuki alto neck and cap at the mo, so we'll see how that goes.
  • 1 month later...
Guest dee1orean
Hiya,
I haven't updated in a while so just wanted to let you know what's going on.
Project has hit a dead stop at the mo which is annoying. I'm not able to keep it at the college any longer due to the fact that we have an over subscribed body repair course this year.
We usually only have two 1st yr groups, this year we have three. Plus two 2nd Yr and one large 3rd year group, which I'm also a part of.
So all these extra students mean we have to bring in extra cars for them to work on so unfortunately my cabby has to go to make way for these inferior models. Though we do have an XJS which we are turning into a track car for one of the members of the Jaguar enthusists club so that'll be fun.
All is not lost though!!! coz I have a lock up!! which I share with four other guys (we are looking for a 5th to make six altogether... it's a large lock up!!) anyway, my MR2 is there at the mo so I'm going to scrap that and store my cabby there.
Trouble is the lock up is about 10-15miles from where I live depending on route. so in order to work on my car I'm going to need to buy a car to drive to the lock up to work on my car, so I'm going to see if I can source a cheap cabby around the £400 mark, which I can then use for spares when the project is complete. won't be for a few months tho as I'm broke due to having most of the summer off.
I'm also going to need a mig welder and a compressor capable of running a spraygun, good news is I'll be in a position to offer bargain resprays for fellow club members but more about that if my plans all pan out.
So there you have it, I haven't given up, merely hit a few obstacles which will be overcome.
Cheers!
Jez.
