mickyfin32 Posted February 19, 2009 Share Posted February 19, 2009 right i converted my cabby from mfi to efi got map sensor got coil pack with it fitted engine fitted loom fitted tank with fuel pump inside fitted fuel computer(fairly easy) put ecu u onto loom put battery on car tries to turn over fuel computer makes noise but not noise from fuel or no spark from leads so i checked yellow relay looks fine swoped it just incase nothing... hmmm looked at tank there a wire with hard casing coming from tank n 2 connectors on some1 said this might be for fuel cut off switch i know its not for tank i connected this one alreay it goes from one in 2 connection into tank so maybe these wires that are hanging over is stoping the pump from priming i hope also i think coil pack might be naff as bought it second hand from scrappy never again i need help otherwise im going to have to scrap her i dont want to i love this car but its costing me too much.. all help n pictures because im a dumb ass would be greatful also if i get it running from your advice i will put my hands in my pocket n pay for a full membership!!!!!!!! (convert me u know u want to ) Link to comment Share on other sites More sharing options...
Guest jonny b Posted February 19, 2009 Share Posted February 19, 2009 Hi Micky , where abouts are you mate? Link to comment Share on other sites More sharing options...
mickyfin32 Posted February 19, 2009 Author Share Posted February 19, 2009 Hi Micky , where abouts are you mate? more then likely a long way from you knowing my luck im a Cardiff lad south wales Link to comment Share on other sites More sharing options...
Guest CHESSYDAVE Posted February 22, 2009 Share Posted February 22, 2009 THE TWO WIRES ARE MOST PROB THE CUTOFF SWITCH JUST TRY CONNECTIN THEM TOGETHER CHENGE THE IGNITION PACK SEE HOW YOU GO IF YOU STILL HAVE PROBS GO BACK TO START AND RETRACE YOUR STEPS YOU JUST MIGHT HAVE OVERLOOK SOMTHING GOOD LOOK MATE LOVE TO COME AND GET STUCK IN BUT FROM CHESTERFIELD DERBYSHIRE PS LET ME KNOW HOW YOU GET ON :Chris: Link to comment Share on other sites More sharing options...
mickyfin32 Posted February 22, 2009 Author Share Posted February 22, 2009 ha ha ha my mates escort fail mot he has efi zetec so might try that bought the engine from ebay derby n loads of things missing i think its without a safety switch also but before i chuck his lump might try some of them will give u feed back gentleman wish me luck total amatuer!!!! Link to comment Share on other sites More sharing options...
Admin Paul Posted February 22, 2009 Admin Share Posted February 22, 2009 Now this might be a stupid question but have you fitted the EDIS unit? Link to comment Share on other sites More sharing options...
mickyfin32 Posted February 23, 2009 Author Share Posted February 23, 2009 aha stupid question to ask what is it? plus i have had a break through while messing about i joined the safety switch wires together n tried it nothing but then i put my mates zetec ecu/brain/silver box on my car nothing put my one back on n it primed¬!!!!! now just got no spark could be anything bad coil pack some1 said to me crank sensor what is it n where ha ha Link to comment Share on other sites More sharing options...
mickyfin32 Posted February 25, 2009 Author Share Posted February 25, 2009 Now this might be a stupid question but have you fitted the EDIS unit? right i knoiw what edis is and yes i have thius unit it looks in good condition n all linked up properly just a random question would a bad earth effect it having no spark? Link to comment Share on other sites More sharing options...
badger Posted February 25, 2009 Share Posted February 25, 2009 aha stupid question to ask what is it? plus i have had a break through while messing about i joined the safety switch wires together n tried it nothing but then i put my mates zetec ecu/brain/silver box on my car nothing put my one back on n it primed¬!!!!! now just got no spark could be anything bad coil pack some1 said to me crank sensor what is it n where ha ha hi fella lets start again when you say you've changed from mfi to efi did you change the whole engine or just the inlet manifolds. Link to comment Share on other sites More sharing options...
