Guest eskey5 Posted October 12, 2007 Share Posted October 12, 2007 Hi can anyone help please...................... ive got a mk5 a and it's leaking in through the front windows, ive tightened the door pins up and changed the rubber round the windscreen and highered the windows but it's still leaking in. It still looks like the windows aint meeting the rubbers properly and it lets in water!!!!!!!!!! does anyone have any suggestions or do i just put up with gettin wet.........????? Link to comment Share on other sites More sharing options...
Guest tom Posted October 12, 2007 Share Posted October 12, 2007 Hi can anyone help please...................... ive got a mk5 a and it's leaking in through the front windows, ive tightened the door pins up and changed the rubber round the windscreen and highered the windows but it's still leaking in. It still looks like the windows aint meeting the rubbers properly and it lets in water!!!!!!!!!! does anyone have any suggestions or do i just put up with gettin wet.........????? mine does this of the windows are up too high - in the end the only way i solved it was to drop the windows about 3mm before shutting the door - that way it fits into the rubber groove but still seals.the other way to do it (apparently) is to get the rubber really hot and then shut the window onto it - apparently it remoulds but i'm not too convinced. Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted October 13, 2007 Share Posted October 13, 2007 Hi Beccy, Mine did the same, just wind your window down a couple of inches with the door OPEN, close it and raise your window fully !!! Link to comment Share on other sites More sharing options...
Admin Ollie Posted October 13, 2007 Admin Share Posted October 13, 2007 hi i am afraid the first thing to do is get yourself some good seat covers then with trial and error try to adjust the windows with the adjuster behind the door cards you will no if you have gone to far as when you shut the door you will have a gap up the side of the window sometimes you can just push the glass under the rubber from outside be carefull though you can also adjust the roof handles a little bit more see if that helps but i am afraid joys of owning a soft top ollie Link to comment Share on other sites More sharing options...
Guest 6tracy9 Posted October 13, 2007 Share Posted October 13, 2007 mine leaks like a sieve!!! But as ollie says the heavy duty waterproof seat covers protect your seats! when i close my door i make sure that the window is tucked under the rubber lip and this stops the window from leaking! when i'm in it and it rains i have to face facts that i'm gonna get wet!!! Link to comment Share on other sites More sharing options...
Vincygav Posted October 22, 2007 Share Posted October 22, 2007 If you can manually push the window up with your hands,once the window is in the up position - then your window regulator is worn and the metal cogs is worn preventing the electric motor jumping the gap. Link to comment Share on other sites More sharing options...
